Fractional Frequency divider using Sigma Delta Modulator
jackeeer
Newbie level 6
Hello everyone,
i am working on sigma delta modulator that I need to use in the fractional divider. Like for now I am facing the noise shaping phenomena and I do not understand one thing... Let me describe the problem:
I know why the noise shaping occurs in sigma delta and can see it in the simulation of 2 nd order sigma delta (verilog model). I am applying 1 kHz sine wave at modulator input and using sampling clock of 1Meg. The noise shaping is present around the frequency of 1kHz, at modulator output hovewer when I use this modulator to control the divider (changing the dividing factor) I can't see the noise shaping around the output signal of divider. For instance I have 10Meg divider input, I am dividing it by 7 or 8 depending on sigma delta output - 0 or 1 and I can't see the noise shaping around 1.4 Meg that I have got at divider output. What I expect is that I will have the same noise shaping around the output fequency as I got around sigma delta output.
My question is...should I expect the noise shaping around output of divider ? How does the sigma delta controling cause the noise around the divider output to be shaped ? I know why I see it at the modulator outptut but I am not sure why should I see it at the divider output also.
Modulator output:
Divider output(i do not why I the output frequency look like this - there is a lot of distortions near the output frequency):
I do not now whether I have presented it clearly...In case of question please ask.
I will provide more data like schematic, simulation results if needed.
Thanks & Regards,
jack
Yes.
Strictly speaking, Noise shaping affects phase not voltage of output signal.
Phase is shaped as lowpass type noise shaping.
And voltage is shaped as bandpass type noise shaping, as far as phase deviation is small.
Zoom around 1.4MHz.
You can see bandpass noise shaping.
Also see the followings.
https://www.designers-guide.org/Forum/YaBB.pl?num=1444923186/6#6
https://www.designers-guide.org/Forum/YaBB.pl?num=1361756819/3#3
You have to understand that noise shaping order of phase reduces by one.
For order_3,
Modualtor have gradient of 60dB/dec.
Phase of divider have gradient of 40dB/dec.
Thanks for your reply pancho_hideboo,
Can you point the place where you see the noise shaping at my printscreen of freq divider output?
I understand the noise may be shaped not so efficient like at the modulator output but I have expected it
shape will be similar. I found some publicaton regarding fractional freq divider that uses sigma delta to
control the div factor and the output spectrum there was as follows:
1:Why do not I see similar thing?
2:Why can't I see single product at the output frequncy? - there are many product near the output that have
comparable magnitude.
I will read more about phase noise shaping...
Thanks one more time,
jackeeer
Surely read my append in https://www.edaboard.com/showthread...equency-divider-using-Sigma-Delta-Modulator#2.
No.
You can not understand anything at all.
2:Why can't I see single product at the output frequncy? - there are many product near the output that have comparable magnitude.
Surely consider bandwidth of spectrum.
Your lowpass noise shaping is 50kHz bandwidth.
And surely understand PLL.
Your spectrum is not PLL.
And your divide-ratio is very small.
This results in large phase deviation.
So small angular approximation can not be satisfied.
Thanks for help. I did another simulation for 10 ms, fin 100 Mhz, div by 3 or 4. I have got following results:
Has anybody know why cant I see the peak at frequency (100MHz/3.5 (3.5 is div factor) ) and the noise shaping?
Regards,
jackeeer
One more question: Does my Noise Shaping bandwidth (thats 50KHz) need to be in some relation with the output frequency of divider?
Regards,
jackeeer
delta_f=0.1kHz.
Divide ratio is too small.
Ntotal=N + delta_N=N*(1+delta_N/N), N=3, delta_N=0 or 1
Max(delta_N/N)=1/3=0.3333 is too large
fout = fin/Ntot
I can not understand what you want to mean at all.
Surey learn very basic things.
Simply clock of your Delta-Sigma-Modulator is 50kHz, that's all.
Can you please tell why I need to increase it instead of saying I need to do it?
For higher dividing ratio the output has too low frequency in compare to sigma delta output - this is why I did not want to do this. Moreover for lower div ratio I need to make my simulating longer...
I can increase the divider ratio let's say 31.5 but what I should do in case I want see the noise shaping for dividing ratio of 3.5 ? Assiming I can't increase the divider ratio...what should I change to see noise shaped?
Regards,
jackeeer
Can you understand Phase Modulation and small angular approximation ?
If not, learn very basic things.
BTW, what frequency do you use as clock of divider ?
For small divide ratio such as 3.5, DSM PLL can not work.
See PLL products of ADI, TI, etc.
I meant "Moreover for HIGHER div ratio I need to make my simulating longer..."
YES, I am familiar with those two concepts however it is first time I do something with sigma-delta modulator and factioanal dividing.
So far I have used 10 MHz and 100 MHz as divider clock input and mostly 20 KHz of SD samppling clock .
"For small divide ratio such as 3.5, DSM PLL can not work." - will not work at all, by definiton? or I need to change something to make it work ?
It is only verilog model based sigma delta and Dual Modulus Divider - i should see somehow the noise shapping at the output but I suppose my sigma delta samppling frequency is in wrong relation to input of frequency divider or something...
I will not use it in PLL - I am working only on Fractional Divider.
Regards,
jackeeer
Can you surely understand very basics of DSM(Delta Sigma Modulator) ?
Instantaneous divide-ratio is Ninst = N + delta_N.
For first order Delta Sigma Modulator generates {0, 1} as delta_N.
N must be far larger than two.
For second order Delta Sigma Modulator generates {-1, 0, 1, 2} as delta_N.
N must be far larger than three.
For third order Delta Sigma Modulator generates {-3, -2, -1, 0, 1, 2, 3, 4} as delta_N.
N must be far larger than five.
So if order of your DSM is truely second, your descriptions are wrong completely.
Is order of your DSM first, isn't it ?
No.
You can not understand even very basic things at all.
If you can truely understand Phase Modulation and small angular approximation, answers are self-evident.
Nints = N + delta_N = N * (1 + delta_N/N)
Tout = Tin * Ninst
fout = fin / Ninst
Output of divider is none of them.
For simplicity, I use sinusoidal.
Vout = A * sin(phase_out)
phase_out = phase_in / Ninst.
Output of divider is Vout.
If delta_N/N is small, sidebands of Vout are far apart.
Moreover output of divider is not sinusoidal.
By definition.
Completely wrong.
Can you surely understand very basics of Sampling theory ?
There is no direct relation between sampling frequency of DSM and input frequency of divider.
Generally, output signal of divider is used as sampling clock of DSM.
However high sampling clock is preferable due to oversampling effect.
High sampling clock than input frequency of divider is nonsense.
and mostly 20 KHz of SD samppling clock.
I don't think your sampling clock is 20kHz.
Judging from https://www.edaboard.com/attachment.php?attachmentid=146635&d=1526336635 is 40kHz.
It seems I need to read more about SD modulators. I thought my dividing ratio will be purely N or N+1 depending on sigma delta output signal - high or low.
I am using following verilog-A code for 2nd order SD modulator. Please look.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
analog begin
      @ ( initial_step ) begin
         vout_val = 1.0;
         hi=1.0;
         lo=-1.0;
      end
      @ (cross(V(vclk), 0))begin
         // summing junction
         vsum = V(vin) - vd ;
         // integrator
         vint = vsum + vint;
         // summing junction
         vsum2 = vint - vd ;
         // integrator
         vint2 = vsum2 + vint2;
         // quantizer
         if (vint2 > vth)
            vout_val = hi ;
     else
            vout_val = lo ;
         // D2A
         vd = vout_high * vout_val ;
      end
      V(vout) <+ transition(vout_val, tdel, trise, tfall);
   end
endmodule
(is there some "code" section I can put it to??? :) )
And also the tbs:
Regards,
jackeeer
Surely learn very basics before posting.
Simply you can not understand even very basic things at all.
Completely wrong.
This is second order DSM ADC of 1bit.
Even if you use correct DSM, you have to increase divide-ratio.
Yes, this is 1 bit output SDM. I use it to investigate on SDM working and noise shaping. As I posted at the begining of this thread I see the noise shaping at the SDM output. I've thought I can use it to control Dual Modulus Divider (n or n+1) and would see the noise shaping...Is there a chance I will see the noise shaping using 1 bit modulator to control DMD?
As I said all above was simulated using verilog-A model however I am designing the secon order SDM using swich capacitor signal integrators, comparators, 1 bit DAC. I see the noise shaping using my transistor based SDM circuit. Why can't I see it using verilog-A model?
Can you please stop saying "Surely learn very basics before posting."? It came to me when you said it in second post. :) I know I need to learn much. I am starting working on SDM and do not understand some concepts but also there is many missunderstandings in our conversation.
Thanks & Regards,
jackeeer
Possible for fisrt order DSM.
Surely see results.
Results must be absolutely wrong.
Simply you can not understand range-scaling and overflow of integrator of DSM.
Simply lack of your ability.
Again see https://www.designers-guide.org/Forum/YaBB.pl?num=1361756819/3#3
https://www.designers-guide.org/Forum/Attachments/hoge_001.jpg
I also use DSM of Verilog-A.
I don't know what simulator you use.
However If you use Cadence dfII, you can find samples in $CDS_TOP_DIR/IC/tools/dfII/samples/artist/pllMMLib.
BTW, I don't use them since I can write more good models by myself
What you can not understand is not only DSM.
Thank you for your honesty.
Correct me if I am wrong:
Does your explanation correspond to MASH type of Sigma Delta ?
If I understand you I can use only 1st order sigma delta for Dual Modulus Divider...For higher orders I need to use MULTI modulus divider that has multi bits control signal....But what when my Second order sigma delta has one bit output like in this case? Is it also unusable to see noise shaping ?
Thanks,
jackeeer
No.
It is true for any DSM structures such as CIFF, CIFB, and MASH.
Attached figure show MASH and CIFF.
Correct.
Correct.
You can not control frequency divider as target fractional divide-ratio.
Simply you can not understand anything.
Noise Shaping and averaging as fractional value are different.
Surely learn range-scaling and overflow of DSM.
Ok, so from your explanation the second order sigma delta (used in fractional divider) should have 2 bits output that will change between following states :{-1, 0, 1, 2} but there is a lot of examples of 2nd order sigma delta that has 1 bit output. SO What are they use for? Are they used only for ADC/DAC conversion ?
Regards,
jackeeer
Yes.
Surely learn and study range scaling of DSM.
