12 MHz oscillator with a Voltage range 120V
kazemihossein33
Newbie level 1
Hello friends
I need a 12 MHz oscillator with a Voltage range of 120V
Preferably designed with cross coupling and non-integrated circuits
If I had a problem with my sentences, I'd like to apologize because I'm not English
Thank you for your guidance
Have you looked at the classic astable multivibrator? It has two cross-coupled transistors. Two capacitors charge and discharge in alternating action.
I have seen this dome with a push pull ckt and controlled capacitance across the fets, ZVS switching with a little range to get the frequency exactly right - PM for more detail ...
