pradhan.rachit
Full Member level 3
Unknown behaviour of differential amplifier for high side current sensing
Dear Experts,
To fulfill the objective of high side current sensing, I am evaluating a differential amplifier operating from a 5V single supply.
The current is being sensed for a performing MPPT for a Solar battery charger and has to be with a low target cost.
Due to low cost consideration, I have refrained from using readily available current sense amplifiers, and instead focusing on building a discrete differential amplifier.
I have chosen the LMV358 which is a low supply, rail-rail op amp.
However, simulating the differential amplifier shows that the op-amp is going beyond saturation and having a voltage higher than VDD at the output. I am unable to find the reason for this. Simulation attached below.
If I replace LMV358 with another rail-rail op amp OPA2340, which has a high unit cost with similar voltage ratings, but low offset voltages. I am able to achieve the desired and proportional result as shown below.
Vout = Rf/Rin*V(Rsense)
Vout ~= 10k/1k * 159.52mV = 1.67V
The voltages at the inputs of the op-amp is varying drastically and seems to be the cause for it. Probably due to input offset voltages?
I would really want to stick to developing a current sensing solution around LMV358. Could someone point me in the right direction to fix this issue? Thanks!
Dear Experts,
