Results 1 to 8 of 8
    Points: 30,053, Level: 42
    Sep 2008
    cambridge
    6,284
    30,053
    42
    cheap soldering iron for 0402 resistors
    Please , do you know of one?
    I suspect it wont need to be temperature regulated.?
    For example, the following Tenma iron….(Part number 9SS-900N-SI)
    http://uk.farnell.com/tenma/9ss-900n...ogo/dp/2565327
    ....has a smallest tip which is part number 5SI-216N-B
    http://uk.farnell.com/tenma/5si-216n...9?st=5si-216nb
    Will this be ok for soldering 0402 resistors? (0402's are on minimal pads on 4 layer FR4 PCB)
    The tip radius is 0.5mm, and I believe that will be too thick for 0402’s?
    •   AltAdvertisment
    Points: 27,514, Level: 40
    BigBoss's Avatar
    Nov 2001
    Turkey
    3,963
    27,514
    40
    Re: cheap soldering iron for 0402 resistors
    This soldering iron cannot anyway work standalone.It's just soldering iron part of this;
    http://uk.farnell.com/tenma/ss-207bc...ngdom%2Fsearch
    Look also other nozzles,I believe some of them are fine.It will-probably-fail in long term otherwise nobody pays few hundreds bucks for professional soldering stations.Think about it..
    •   AltAdvertisment
    Points: 48,823, Level: 53
    Apr 2011
    Minneapolis, Minnesota, USA
    12,143
    48,823
    53
    To solder tiny pieces I sometimes wind a short loop of wire around the tip of my 100W soldering gun. It quickly delivers heat to the work. I can join parts quickly. The solder cools quickly because contact time was brief.
    Whereas, I've seen my little soldering iron fail to melt solder when doing a few joints. I can't be sure if it's cooled down, or whether a layer of char has developed, inhibiting heat transfer. While I wait for solder to melt, the workpiece carries heat away from the join area.
    •   AltAdvertisment
    Points: 36,970, Level: 47
    Mar 2008
    USA
    5,950
    36,970
    47
    A tiny-nozzle heat gun and solder paste (in syringe)
    could be closer to what normal surface-mount assembly
    is like. The resistors probably don't care about their
    body being heated to solder liquidus temp, unlike ICs
    which often spec 10 sec @ 300C max.
    A fat flat tip could heat both endcaps at once and let
    you "iron, dot, dot" solder the components. You might
    even "sacrifice" such a tip (or few) and file out a notch
    in the tip such that the "fork" now hits only the endcaps.
    Cheap irons often offer only lousy tip geometries. But
    back when I was a broke-a$$ student I would pick up
    brass bolts at the hardware store (or steal from work)
    and grind them to suit - cheapo irons use standard
    threads for the tips which are nickel plated copper.
    Of course a pack of cheapo replacement tips ought
    to be pretty inexpensive too, if you wanted to play
    with geometries (less length will let more heat flow
    to the tip, you might like a short shaft and a needle
    point, or pound one flat and make the "fork" like I
    mention, etc.).
    But a cheapo iron is also likely not temperature
    controlled, only power limited, and will be inferior
    for any large thermal mass (including boards with
    a heavy ground plane if the solder lands are well
    connected to it, thermally).
    Full Member level 6
    Points: 2,730, Level: 12
    SLK001's Avatar
    Aug 2015
    Coral Springs, Florida
    377
    2,730
    12
    I use two soldering irons for all my two port surface mount devices. For 0402, I use fairly narrow tips. Both irons are temp controlled (Hakko 926). Avoid hot air - you would be surprised at how easy 0402s are blown away. And with them being unmarked, plus the size of grains of sand, once they are gone, you will have to re-place a new part.
    Points: 14,409, Level: 28
    Nov 2012
    2,664
    14,409
    28
    Quote Originally Posted by treez View Post
    This is cheap; really! Not in price though and you can get two for the same price from alibaba.
    If you can see them you can solder them! The most common problem is that you do not have enough space to put the soldering iron tip to touch the board.
  7. #7
    Member level 3
    Points: 660, Level: 5
    May 2016
    Turkey
    59
    660
    Even the cheapest soldering irons would work with its standart tip actually. I am not saying they are the perfect fit for the job, but if you just want to solder 0402 passives to your PCB you can pretty much any soldering iron.
    •   AltAdvertisment
  8. #8
    Advanced Member level 3
    Points: 6,600, Level: 19
    Jan 2015
    957
    6,600
    19
    Also think about what else you might want to do with the soldering iron. By all means get a soldering iron that handles small SMT devices but (In my opinion) it would be a waste to only think of soldering 0402 resistors (or just 0402 sized devices).
    To me, the key thing is the size of the tip - it has to be small enough to heat the pad and the side of the component or IC pin. The next thing is ensuring that the tip is supplied with enough heat that it will not cool down too much when it does get applied to the pad/component which generally means a more powerful element (perhaps even temperature controlled) to maintain the tip temperature.
    Susan
