Is sGDMA integration correct in this SoC ??
hcu
Hello all,
I am using modular scatter-gather DMA core to transfer data from my custom IP: custom_design_32_0 to other custom IP: custom_design_32_1 on the stratix 10 development board.
I want to work on this in the simple way without using any additional prefetcher cores or anything else !!!
Anybody please verify and suggest me that , Is connections are ok ?
If this ok, I want a sdk c files to proceed further.
Regards,
Did you push the "Validate System Integrity" button?
I haven't used Altera tools in almost a decade but it looks like that might perform a DRC check on the design. If it passes that it's probably okay.
I pressed the button, it is success . but don't know how to proceed further. I want a working C code.
The tools won't write C code for you, that is something you (the designer) is supposed to write. The tools might supply a basic framework, e.g. a main routine with hello world and a header file that includes the addressing of your system, that you can modify to suit your needs.
I am looking for a template of dma controller c file and want to use it. Yes i know , xilinx sdk have a inbuilt example dma code where i used to call ...init() function and a ..dma_transfer(src,dest,bytes) function to get started bursting.
but in altera sdk , i found nothing and i dont think i can built one from scratch. If you people have one or an example please let me know.
