How To Indetify A Chipset
aspedon
I found some stock components in my office warehouse. Unfortunately no one knows the type and function. Looking at the logo, it appears that he was produced by Texas Instrument. However I was browsing on the TI web, not finding any meaningful hints. I tried googling, also still find the answer. Has anyone here used this part? I need the datasheet. Thanks.
Are you sure this is the exact photo of the device you have?
Hello Sir, Thanks for your reply.
I do not have the original product with enough clarity. So I made a picture like that. All text, logo, I write like the original picture.
Helo Sir,
Thanks for your Reply. I do not have the original product with enough clarity. So I made a picture like that. All text, logo, I write like the original picture.
Aspedon
I agree with you, but I did not find any information (datasheet) about the IC on Texas Instrument website (www.ti.com). Because the amount of stock is very much, it's a pity if not used :cool:
Is the numbering exactly the same as the one in the image? (0402092)
It may be a house code, a generic or custom device but marked according to the customers order instead of it's normal marking. Where did you get the image from?
It read clearly on the ic. But I do not have a camera that is good enough to take a picture. So I made the picture as above.
Whoooo ... maybe you are right, this is a custom product. Very reasonable.
Case closed :thumbsup: Unless someone else can provide different information.
Thank you sir.
Aspedon.
