Aussie Susan
Advanced Member level 5
And what have you learned from this exercise?@ arexxx, you are a great friend. This code works fine. You just did a great work here. You really are in this stuff.
If the requirements change (or become clearer), can you alter the code?
Or will you always be requiring mcmsat13 (or someone else) to update things for you?
In post #14, you said that you wanted to learn about coding MCUs. There are *many* examples available for the various makes of devices out there. I suggest that you select one that has basic tutorials available and then start with simple programs such as 'flash a LED' and build up from there. Many manufacturers make 'prototyping' or 'experimenter' kits that provide the hardware and ways to access the built-in capabilities (and often built-in programmers as well). That way you will really learn about these devices and what they can do in a way that is meaningful to you.
Susan
