Merging pin-tagged nets in Cadence
sci-fi_guy
I have a schematic and layout in Cadence that includes multiple independent power lines. I created them on the schematic and used pins for these power lines. However, on the layout, I am experiencing some problems due to Cadence not recognizing those pins as vdd or gnd. Is it possible for me to force the pin-tagged nets to be be merged on the layout without actually creating a physical connection?
Thanks in advance.
Dependent on which licenses you have.
Do you mean to connect them during the physical verification (LVS)?
Or to a specific net inside the virtuoso environment?
For the LVS it depends on if you have calibre or assura or PVS - they all treat it slightly differently dependent on how the kits are set up.
For the virtuoso environment, you should be able to just modify the connectivity property (might have to dbCreateNet first).
