Results 1 to 4 of 4
    Newbie level 2
    Points: 20, Level: 1
    Apr 2018
    20
    VHDL. Failed Timing. Division
    Hello, I am new to VHDL. I want to make frequency meter from 1KHz to 300kHz and have one problem.
    I use division which have great impact to timing. So maybe someone have some ideas how to solve this ?
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.numeric_std.ALL;
    entity Freq_Counter is
        Port (  Clk : in STD_LOGIC;
              Data : in STD_LOGIC;
               seg : out STD_LOGIC_VECTOR (6 downto 0);
               an: out STD_LOGIC_VECTOR (3 downto 0));
    end Freq_Counter;
    architecture Behavioral of Freq_Counter is
    signal SD1 :  std_logic_vector(3 downto 0):="0000" ;
    signal SD2 :  std_logic_vector(3 downto 0):="0000" ;
    signal SD3 :  std_logic_vector(3 downto 0):="0000" ;
    signal Freq:integer range 0 to 300 :=0;
    signal N_Ticks: integer range 0 to 50000 :=0;
    component Segment
    port(
    Clk : in STD_LOGIC;
    Value1 : in STD_LOGIC_VECTOR (3 downto 0);
    Value2 : in STD_LOGIC_VECTOR (3 downto 0);
    Value3 : in STD_LOGIC_VECTOR (3 downto 0);
    end component;
    begin
    Segments : Segment
    port map(
    Clk => Clk,
    Value1 => SD1,
    Value2 => SD2,
    Value3 => SD3,
    seg => seg,
    an => an);
    process(Data,Clk)
    Variable Ready : integer range 0 to 3 :=0;
    Variable N_Tick: integer range 0 to 50000 :=0;
    begin
    --------------------------BEGIN----------------------------
    if Clk'event and Clk ='1' then
    case Ready is
    when 0 =>
        if Data ='1' then
            Ready :=1;
        end if;
    when 1 =>
        N_tick := N_tick +1;
        if Data ='0' then
            Ready:=2;
        end if;
       if N_tick > 100000 then
                 N_tick:=0;
                 Ready:=3;
                 end if;
    when 2 =>
        if Data ='1' then
         N_ticks <= N_tick;
         Ready:=3;
        end if;
             N_tick:=0;
             Ready:=3;
             end if;
    when 3 =>
     if Data ='0' then
     N_tick:=0;
     Ready:=0;
     end if;
     end case;
     end if;
     END PROCESS;
    process(CLK)
    constant Speed : integer:=100000;
    Variable duom1 : integer range 0 to 100000 :=0;
    begin
    duom1:=duom1+1;
    if duom1>10000 then
    Freq <= Speed/N_ticks;
    duom1:=0;
      end if;
      end if;
     END PROCESS;
     process(CLK)
     Variable D1 : integer range 0 to 9 :=0;
     Variable D2 : integer range 0 to 9 :=0;
     Variable D3 : integer range 0 to 9 :=0;
     Variable  duom2 : integer range 0 to 100000 :=0;
     begin
    duom2:=duom2+1;
    if duom2 > 10000 then
    D3 := freq/100;
    D2 :=(freq/10)mod 10 ;
    D1 := freq mod 10;
    if D1 = 1 then
    SD1 <= "0001";
    elsif D1 = 2 then
    SD1 <= "0010";
    elsif D1 = 3 then
    SD1 <= "0011";
    elsif D1 = 4 then
    SD1 <= "0100";
    elsif D1 = 5 then
    SD1 <= "0101";
    elsif D1 = 6 then
    SD1 <= "0110";
    elsif D1 = 7 then
    SD1 <= "0111";
    elsif D1 = 8 then
    SD1 <= "1000";
    elsif D1 = 9 then
    SD1 <= "1001";
    else
    SD1 <= "0000";
    end if;
    if D2 = 1 then
    SD2 <= "0001";
    elsif D2 = 2 then
    SD2 <= "0010";
    elsif D2 = 3 then
    SD2 <= "0011";
    elsif D2 = 4 then
    SD2 <= "0100";
    elsif D2 = 5 then
    SD2 <= "0101";
    elsif D2 = 6 then
    SD2 <= "0110";
    elsif D2 = 7 then
    SD2 <= "0111";
    elsif D2 = 8 then
    SD2 <= "1000";
    elsif D2 = 9 then
    SD2 <= "1001";
    else
    SD2 <= "0000";
    end if;
    if D3 = 1 then
    SD3 <= "0001";
    elsif D3 = 2 then
    SD3 <= "0010";
    elsif D3 = 3 then
    SD3 <= "0011";
    elsif D3 = 4 then
    SD3 <= "0100";
    elsif D3 = 5 then
    SD3 <= "0101";
    elsif D3 = 6 then
    SD3 <= "0110";
    elsif D3 = 7 then
    SD3 <= "0111";
    elsif D3 = 8 then
    SD3 <= "1000";
    elsif D3 = 9 then
    SD3 <= "1001";
    else
    SD3 <= "0000";
    end if;
    duom2:=0;
    end if;
    end if;
    end process;
    end Behavioral;
    •   AltAdvertisment
    Advanced Member level 3
    Points: 5,707, Level: 17
    Feb 2015
    942
    5,707
    17
    Re: VHDL. Failed Timing. Division
    For practical implementation, I would use a small FSM. Basically, a design where there is a counter that accumulates count for 1 second. After that, use the basic "can I subtract 100000, 10000, 1000?" FSM to count the number of 100000 that can be subtracted, then the number of 10000 that can be subtracted, then the number of 1000 that can be subtracted. These become the signals to the bcd converter. This is probably what the assignment wants you to do.
    •   AltAdvertisment
    Newbie level 2
    Apr 2018
    20
    thank you. I have though about such solution, but i hoped that there is easier way to do it.
    •   AltAdvertisment
    Points: 250,714, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,647
    250,714
    100
    Ultimately, the divider timing problems are brought up because you want the result in a single clock cycle instead of enabling useful pipelining. The division is only needed once per measurement cycle and doesn't need to be particularly fast. An economic serial divider can be used for this purpose.
    There are other design details that have negative timing effects like that usage of variables.
