promach
Does <= (reg) changes value at the same clk posedge or the next clk posedge in simula
For https://i.imgur.com/P5svAaL.png , I am getting assignment at different clk posedge for https://github.com/promach/UART/blob/development/rtl/Rx/synchronizer.v#L19 and https://github.com/promach/UART/blob/development/rtl/Rx/rx_state.v#L44
Why is that so ?
synchronizer.v
rx_state.v
Why is that so ?
synchronizer.v
module synchronizer(clk, reset, serial_in, serial_in_synced); // 3FF synchronizer
input clk, reset, serial_in;
output reg serial_in_synced; // third FF
reg serial_in_reg, serial_in_reg2;
always @(posedge clk)
begin
if(reset) begin
serial_in_reg <= 1; // first FF
serial_in_reg2 <= 1; // second FF
serial_in_synced <= 1; // third FF
end
else begin
serial_in_reg <= serial_in; // first FF
serial_in_reg2 <= serial_in_reg; // second FF
serial_in_synced <= serial_in_reg2; // third FF
end
end
initial begin
serial_in_reg = 1;
serial_in_reg2 = 1;
serial_in_synced = 1;
end
`ifdef FORMAL
reg first_clock_passed = 0;
always @(posedge clk) first_clock_passed <= 1;
begin
if(reset) begin
assert(serial_in_reg == 1);
assert(serial_in_reg2 == 1);
assert(serial_in_synced == 1);
end
else begin
if(first_clock_passed) begin
// for induction
assert(serial_in_reg == $past(serial_in));
assert(serial_in_reg2 == $past(serial_in_reg));
end
end
end
`endif
endmodule
rx_state.v
module rx_state(clk, reset, start_detected, sampling_strobe, data_is_available, data_is_valid, is_parity_stage, state); // FSM for UART Rx
parameter INPUT_DATA_WIDTH = 8;
localparam NUMBER_OF_BITS = INPUT_DATA_WIDTH + 3; // 1 start bit, 8 data bits, 1 parity bit, 1 stop bit
input clk, reset, start_detected, sampling_strobe;
output reg data_is_available; // in data states
output reg is_parity_stage;
output reg data_is_valid; // finished all data states
output reg [($clog2(NUMBER_OF_BITS)-1) : 0] state;
localparam Rx_IDLE = 4'b0000;
localparam Rx_START_BIT = 4'b0001;
localparam Rx_DATA_BIT_0 = 4'b0010;
localparam Rx_DATA_BIT_1 = 4'b0011;
localparam Rx_DATA_BIT_2 = 4'b0100;
localparam Rx_DATA_BIT_3 = 4'b0101;
localparam Rx_DATA_BIT_4 = 4'b0110;
localparam Rx_DATA_BIT_5 = 4'b0111;
localparam Rx_DATA_BIT_6 = 4'b1000;
localparam Rx_DATA_BIT_7 = 4'b1001;
localparam Rx_PARITY_BIT = 4'b1010;
localparam Rx_STOP_BIT = 4'b1011;
initial begin
data_is_available = 0;
is_parity_stage = 0;
data_is_valid = 0;
state = 0;
end
begin
if(reset) begin
data_is_valid <= 0;
is_parity_stage <= 0;
data_is_available <= 0;
end
else begin
data_is_valid <= (state == Rx_STOP_BIT); // so as to align with rx_error
is_parity_stage <= (state == Rx_PARITY_BIT); // parity state
data_is_available <= (sampling_strobe && (state == Rx_START_BIT)) || ((state >= Rx_DATA_BIT_0) && (state <= Rx_DATA_BIT_7)); // data states
end
end
begin
if (reset)
state <= Rx_IDLE;
else begin
if (sampling_strobe) begin
case(state)
Rx_IDLE : state <= (start_detected) ? Rx_START_BIT : Rx_IDLE;
Rx_START_BIT : state <= Rx_DATA_BIT_0;
Rx_DATA_BIT_0,
Rx_DATA_BIT_1,
Rx_DATA_BIT_2,
Rx_DATA_BIT_3,
Rx_DATA_BIT_4,
Rx_DATA_BIT_5,
Rx_DATA_BIT_6,
Rx_DATA_BIT_7 : state <= state + 1'b1;
Rx_PARITY_BIT : state <= Rx_STOP_BIT;
Rx_STOP_BIT : state <= Rx_IDLE;
default : state <= Rx_IDLE;
endcase
end
else begin // start bit falling edge is detected every clock cycle for better Rx synchronization accuracy
if((state == Rx_IDLE) && (start_detected))
state <= Rx_START_BIT;
end
end
end
`ifdef FORMAL
begin
assert(state <= Rx_STOP_BIT);
if(((state == Rx_DATA_BIT_0) && ($past(state) == Rx_DATA_BIT_0)) || ((state > Rx_DATA_BIT_0) && (state <= Rx_DATA_BIT_7))) begin
assert(data_is_available);
end
//if (state == Rx_STOP_BIT)
//assume(reset == 0); // this is to assume for induction test because Tx internal registers are not reset/initialized properly at time = 0, such that data_is_valid signal will not be asserted in the next clock cycle after the "FIRST" stop bit state
end
`endif
endmodule
