+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 2
    Points: 23, Level: 1
    Join Date
    Apr 2018
    Posts
    Points
    23
    Level
    Nonconstant index in Verilog
    Hi
    I want to check if "N" bits bus are all logic 1 and assign to the "pass" signal. The
    bus width is variable and is defined by parameter N. But I get the "nonconstant index"
    error message. How can I fix this issue?
    Any help would be greatly appreciated!
    parameter N;//2~64
    integer i;
    reg [(N*N)-1 : 0] status;
    reg [N-1:0] pass;
    //pass[0] is for status[N-1:0], pass[1] is for status[(2*N)-1 : N] ... ,etc
    always @(status)
      for(i=0;i<=N-1;i=i+1)
        pass[i] =  & status[N-1+(i*N) : (i*N)];
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 32,190, Level: 43
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    7,440
    Points
    32,190
    Level
    43
    Re: Nonconstant index in Verilog
    If I interpreted what you are trying to do correctly...
       pass[i] =  & status[(i*N) +: N];
    should do what you want.
    Both the upper and lower bounds of a slice can't both be calculated
    1 members found this post helpful.
    •   AltAdvertisement
  3. #3
    Points: 6,391, Level: 19
    Join Date
    Feb 2015
    Posts
    1,039
    Points
    6,391
    Level
    19
    This is an artificial Verilog-ism. VHDL is totally fine with this -- other than lacking +:.
    For Verilog, you can do:
    pass[i] =  &((status >> (i*N)) & ((1<<(N+1))-1));
    // or
    pass[i] =  &((status >> (i*N)) & (N){1'b1});
    although it feels like a hack.
    I'd like to know if there are better solutions. I think the last time I tried this was 1 year ago, maybe Verilog allows +: with variable index now.
    --edit: not sure on the precedence of >> vs *. either way it's probably not clear to many readers.
    --edit2: actually, it looks like +: should work. I have no idea why it didn't the last time I tried it. maybe I made some other mistake. It looks like the LRM has an example for this case. If +: works, use it, it is a better construct anyways.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Points: 264,377, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    46,200
    Points
    264,377
    Level
    100
    Indexed part select syntax +: and -: is supported at least since Verilog 2001.
