Results 1 to 6 of 6
    Points: 259, Level: 3
    Apr 2018
    32
    259
    Automatic Door Materials.
    Can the Automatic door technology applicable to other materials Viz Wood,Steel,Iron other than Glass?.
    I.e Automatic Opening and Closing of Door sensing Human Being Object?.
    Thanks & Regards,
    Prashant S Akerkar
    •   AltAdvertisment
    Points: 70,834, Level: 64
    Apr 2014
    14,484
    70,834
    64
    Re: Automatic Door Materials.
    Your question isnīt clear.
    Please ask more elaborated questions.
    In case your question is about the "sensor", then the answer is: the sensor usually isnīt related to the door material at all.
    The sensor is optimized to react on human movement or human IR (emission or reflection).
    There are several sensor types, like PIR or radar.
    •   AltAdvertisment
    Apr 2018
    32
    259
    Thank you.
    In that case,I can use any door material Viz Steel,Iron,Wood etc for automatic opening and closing of Doors on detection of Human Being Object ?.
    Thanks & Regards,
    Prashant S Akerkar
    •   AltAdvertisment
    Full Member level 3
    Points: 2,965, Level: 12
    amol_shah's Avatar
    Apr 2008
    Nasik
    153
    2,965
    12
    Yes you can use any door material as per your requirement. All you require is the mechanical assembly and motor with sufficient torque for opening and closing the door
    Points: 50,911, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,505
    50,911
    55
    There are various trade-offs to consider.
    Glass lets you see if the door is about to open toward you due to someone approaching, or if cannot open for you due to an obstacle on the other side.
    The lighter the weight of the door, the easier it is on a motor to move and stop.
    •   AltAdvertisment
    Full Member level 6
    Points: 2,148, Level: 10
    Nov 2016
    348
    2,148
    10
    I imagine there are automatic swinging doors, but the majority I would think are sliding doors.
