How to insert multiple vias in a same microstrip line
ndequeiroz
Junior Member level 3
How to insert more than one via to ground in a microstrip line on ads?
I'm trying to ground properly this via, but i don't know how do that... And is my via correct? I used the VIA GND component...
What are you trying to do?
If this is for Momentum EM simulation, you can copy this via instance, or draw objects on a layer that you map as via in the Momentum substrate file.
