Results 1 to 8 of 8
    Full Member level 3
    Points: 1,275, Level: 8
    BiNa2605's Avatar
    Sep 2015
    VietNam
    179
    1,275
    8
    Need Robot climb on wall explainations
    Does anyone know how robot car can climb on wall? I saw the videos on Facebook about Robotic competition. I am highly appreciate for any explainations of resources. Thanks.
    I guess on the bottom surface of robot have a stickly material. I'm not sure.
    https://www.facebook.com/RCoradea/vi...4108511850995/
    •   AltAdvertisment
    Points: 8,479, Level: 22
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,516
    8,479
    22
    Re: Need Robot climb on wall explainations
    There are 2 fans on both sides which is inverting the gravity :)
    Love me or hate me. All infractions will be ignored.
    Full Member level 3
    BiNa2605's Avatar
    Sep 2015
    VietNam
    179
    1,275
    8
    Could you give me any materials, sir?
    •   AltAdvertisment
    Newbie level 6
    Points: 79, Level: 1
    Apr 2018
    Pakistan
    13
    79
    For Wall Climbing Robot, you need to use some pneumatic valves. A rubber front like in arrows to **** the air and then place their grip on the wall.
    You must have seen gun arrows for children and when they shoot it those arrows just stick to the wall because of air suction. You have to design something like that.
    Thanks.
    Technopreneur B|
    Full Member level 5
    Points: 1,805, Level: 9
    Nov 2016
    301
    1,805
    9
    Go to YouTube and search "watch this robot climb up walls". The robot has two fans and the tires contact the wall first. When it reaches the wall the front fan lifts the front end while the back wheels roll forward. Once vertical the fans keep the car pressed against the wall and tilt slightly forward or backwards depending on what direction you want to go.
    What would be cool is if it could fly like a drone and then land upside down on the ceiling like a bug. If you could pull that off we might be seeing you on that television program.
    •   AltAdvertisment
    Newbie level 6
    Apr 2018
    Pakistan
    13
    79
    Fan option is also gud but it will be quite difficult because in this case you have to use brushless DC Motor as in quadcopter to create the thrust.
    Technopreneur B|
  7. #7
    Full Member level 5
    Nov 2016
    301
    1,805
    9
    Suction cups was also a good idea. Provided it is a slick smooth surface.
  8. #8
    Newbie level 6
    Apr 2018
    Pakistan
    13
    79
    Yeah right, normally it's used when robots need to climb on mirrors.
