Results 1 to 2 of 2
    Points: 887, Level: 6
    Nov 2014
    48
    887
    Compatibility of DVB-S2 modems
    why aren’t satellite modems from different vendors compatible with each other even when DVB-S2 is implemented? Because of different application layer protocals?
    Senmeis
    •   AltAdvertisment
    Points: 72,330, Level: 65
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,856
    72,330
    65
    Re: Compatibility of DVB-S2 modems
    It's due to contractual reasons. The data streams are compatible, assuming the same transmission parameters are used, but firmware blocks or allows access so only the subscribed packets are available. If they were fully compatible it would be possible to receive data intended for a different user. Bear in mind there could be thousands of users sharing a single data stream so ensuring security is paramount.
