Results 1 to 3 of 3
    Full Member level 5
    Points: 3,136, Level: 13
    Feb 2008
    Turkiye
    257
    3,136
    13
    Thread-safe usage of logger
    Hi colleagues;
    I want to use a logger lib for my application in C. I found this on github, it seems quite fit my purposes. My question, how can i use it thread-safely?
    In my application, i have two threads and both uses logger function (to print a file or stderr). Author gives a function for this purpose -log_set_lock(log_LockFn fn)- but i couldn't figure out how to use it?
    https://github.com/rxi/log.c/#log_set_locklog_lockfn-fn
    If the log will be written to from multiple threads a lock function can be set. The function is passed a udata value (set by log_set_udata()) and the integer 1 if the lock should be acquired or 0 if the lock should be released.
    Thanks for help
    •   AltAdvertisment
    Member level 3
    Points: 381, Level: 4
    Created Blog entry
    Apr 2018
    Gdańsk, Poland
    63
    381
    Blog Entries
    Re: Thread-safe usage of logger
    I suggest to create another thread for logging/printing purposes only (to a file or stderr) with a FIFO.
    This thread would be woken up only when something is in the FIFO. The content of this FIFO would be logged/printed.
    Then other threads could write theirs records into that FIFO to make theirs log.
    •   AltAdvertisment
    Full Member level 5
    Feb 2008
    Turkiye
    257
    3,136
    13
    Thanks for your suggestion.
    Meanwhile, i think i have found the solution by myself. Here is the explanation;
    - Define a mutex
    - Define a function to lock and unlock defined mutex
    - Pass mutex pointer to logger library by using log_set_udata().
    - Pass function to logger library by log_set_lock().
    Hence (if you look at log_log() implementation) each time you call log function, it will call the defined function to make a mutex lock/unlock.
    You can test it by manually locking the mutex and calling log_() function. It couldn't print till you manually unlock the defined mutex.
    void locklogger(void *udata, int lock)
    	if (lock)
    		pthread_mutex_lock(udata);
    	else
    		pthread_mutex_unlock(udata);
    //in main
    pthread_mutex_t loglock= PTHREAD_MUTEX_INITIALIZER;
    log_set_udata(&loglock);
    log_set_lock(locklogger);
