Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
  1. #21
    Points: 48,299, Level: 53
    Apr 2011
    Minneapolis, Minnesota, USA
    12,023
    48,299
    53
    Re: [moved] Rectifier design with impedance matching ckt
    The input impedance for the impedance matching network will be 50 ohms, right?
    A diode automatically adjusts its internal resistance, so that current and voltage obey its particular equation. Suppose you get 1 mA and 0.4V. Therefore the diode presents 400 ohms.
    Suppose its 15mA and 0.5V. Then diode resistance is 33 ohms.
    To improve efficiency your antenna ought to be a size and shape which picks up sufficient rf, so that it generates voltage high enough to overcome diode threshold voltage.
    •   AltAdvertisment
  2. #22
    Member level 5
    Points: 1,024, Level: 7
    Mar 2015
    93
    1,024
    7
    Thank you for the reply :)
    Can you please check my circuit in ADS which I have attached in the previous post in the same thread and tell me the modifications / improvements required?
