Results 1 to 5 of 5
    Points: 85, Level: 1
    Mar 2018
    7
    85
    X5R, 1uf Ceramic Capacitor Max survival temperature
    I am using TDK Part# C1005X5R1V105K050BC (Description: CAP CER 1uF 10% 35V X5R 0402) and it specification says as operating temperature is -67F(-55C) to +185F(85C).
    Can anyone please let me know:
    1. What will be its max survival temperature ? (not mentioned is datasheet)
    2. What will happen it I subject same capacitor to +221F(105C) ? (Reliability and Functional Point of view) (Cap is connected on non-critical digital line of 5V)
    Thanks & Regards,
    Azhar
    •   Alt11th April 2018, 12:10
      advertising
    Points: 60,133, Level: 59
    Apr 2014
    12,277
    60,133
    59
    Re: X5R, 1uf Ceramic Capacitor Max survival temperature
    In future please give a link to the datasheet or upload it - it saves our time you may expect more and faster response.
    Id say the datasheet is very clear in this:
    * operational temperature limit: 85C
    * non-operational peak temperature limit: 260C, Time : 50.5s. This is in the soldering specifications.
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    •   Alt11th April 2018, 12:47
      advertising
    Points: 19,887, Level: 34
    Jan 2011
    3,294
    19,887
    34
    "Survival temperature" isn't a well-defined term, which is why you can't find it in a datasheet.
    Assuming you don't have any issues due to thermal expansion of the PCB (which the capacitor manufacturer can't know), the main symptom you'll see at high temperature is increased leakage current and poor insulation resistance. This effect, and how much of it persists after cooling down, will depend a great deal on the bias voltage and humidity at the time. For a supply bypassing capacitor this may not be an issue, but that depends on your application.
    •   Alt23rd April 2018, 21:36
      advertising
    Advanced Member level 3
    Points: 6,233, Level: 18
    Aug 2015
    978
    6,233
    18
    you can run them hot - but they may not last - the thermal cycling - if not at a constant 1o5C - is what will get them in the end - unless soldered with soft solder - the bigger packages, >>1206, have flex tab ends to allow for this ...
    basically the pcb expands and the chip caps don't - if you get a match for thermal expansion - then you are on a winner
    also derate the caps so the current thru them does not cause too much self heating ( 100mw say for a 1206 part)
    good luck ...
    Points: 12,166, Level: 26
    Feb 2010
    UNITED KINGDOM
    1,925
    12,166
    26
    Quote Originally Posted by AzharElectronics View Post
    Operating temperature is the temp. range the cap can be operated at, if there is a storage temp range then the cap can be stored at those temps but not powered, quite simple really isn't it. If you operate a component outside of it's temp range then expect problems.
