Results 1 to 14 of 14
    Newbie level 5
    Points: 113, Level: 1
    Dec 2017
    9
    113
    Understanding switched mode power supplies
    Hello everyone
    Can someone please help me in understanding the right half plane zero problem usually found in switched mode power supplies(SMPS)? Please tell me the problem created by the right half plane zero in
    SMPS and solution for the same.
    •   AltAdvertisment
    Points: 6,724, Level: 19
    Dec 2015
    Madrid, Spain
    1,206
    6,724
    19
    Re: Understanding switched mode power supplies
    RHP zero gives a phase inversion, so the output will take the opposite path before returning back to normality. Compensator should not see that, so it must have reduced BW.
    Points: 15,926, Level: 30
    E-design's Avatar
    Jun 2002
    2,014
    15,926
    30
    It is usually only a problem that comes up with indirect transfer converters, like boost, buck-boost and flyback. Operating deep into CCM will make the problem worse, and as stated the crossover must be reduced very low to avoid the RHP zero effects.
    Advanced Member level 1
    Points: 3,306, Level: 13
    Feb 2014
    412
    3,306
    13
    In plain language a right hand plane zero means that the initial response of the system to a “request” for more voltage is that voltage briefly dips.
    It’s like some cars where if you floor the gas the engine will lose power at first before picking up speed.
    This is a inherent property of sometopologies but not others.
    The bottom line is that while sources feel a need to mention it, it rarely matters unless you’re really trying to push the performance of your system. If loop bandwidth 1/10th or lower of the switching frequency, which is typical, it doesn’t matter.
    3 members found this post helpful.
    •   AltAdvertisment
    Newbie level 5
    Dec 2017
    9
    113
    How can I lower the crossover?
    E-design's Avatar
    Jun 2002
    2,014
    15,926
    30
    You will select the proper feedback value capacitor on the error amplifier opamp to reduce the total gain to 0 dB at the desired crossover frequency.
    •   AltAdvertisment
  7. #7
    Newbie level 5
    Dec 2017
    9
    113
    Does reducing the crossover frequency reduce the bandwidth also??
  8. #8
    Feb 2014
    412
    3,306
    13
    Quote Originally Posted by ShubhamSharma View Post
    Yes that's the same thing.
  9. #9
    Newbie level 5
    Dec 2017
    9
    113
    What is the effect on the stability due to the reduced bandwidth? If there is a trade off between stability and bandwidth, then how can it be solved?
  10. #10
    Feb 2014
    412
    3,306
    13
    No, in power supplies lower bandwidth almost always makes stability easier.
    So much time is devoted to studying advanced compensation schemes but actually standard converters can all be stabilized with a 1-pole integrator.
    So the point of 'fancier' compensation schemes isn't stability - it's stability AND performance (high bandwidth).
  11. #11
    Points: 29,248, Level: 41
    Sep 2008
    cambridge
    6,124
    29,248
    41
    RHPZ is to be heeded, as you know.
    Your crossover frequency shopuld be no more than a third of your rhpz frequency.
    The book by Basso gives the rhpz frequency for various converter topologies.
    Discontinuous mode converters dont have RHPZ's.
    Also, Buck converters dont have RHPZ's.
    Also remember that constant off time control means you dont get an RHPZ
    •   AltAdvertisment
  12. #12
    Newbie level 5
    Dec 2017
    9
    113
    What are other ways, besides reducing the crossover frequency, to nullify the effect of RHPZ in switched mode power supplies?
  13. #13
    Points: 19,982, Level: 34
    Jan 2011
    3,307
    19,982
    34
    Only two options:
    1. Use another topology which doesn't have the RHPZ (buck-derived topologies).
    2. Don't operate in continuous conduction mode.
    If you use a buckboost or boost-derived topology in CCM, then the RHPZ will be present, and its effects cannot be "nullified." You can raise the RHPZ frequency somewhat by decreasing your inductance, or just cut your control bandwidth, but obviously those two options have drawbacks.
  14. #14
    Newbie level 5
    Dec 2017
    9
    113
    can you tell me the value of voltage sources used in the circuit so that we can perform the simulation?
