Results 1 to 10 of 10
    Points: 12,407, Level: 26
    Aug 2011
    2,505
    12,407
    26
    Converting an array of std_logic to string
    My entity's "generic" section has a set of 5 enabling configurations (that are concatenated into a vector ) - as follows:
    entity some_entity is
    generic
       enable_0 : std_logic ;
       enable_1 : std_logic ;
       enable_2 : std_logic ;
       enable_3 : std_logic ;
       enable_4 : std_logic ;
    port
    end entity some_entity ;
    architecture rtl_some_entity is
    constant concatenated_enables : std_logic_vector ( 4 downto 0 ) := enable_4 & enable_3 & enable_2 & enable_1 & enable_0 ;
    constant configuration_sting : string := std_logic_vector_to_string (concatenated_enables ) ;
    begin
    end architecture rtl_some_entity ;
    The function marked in red shall return the Hex value of "concatenated_enables" in a string format.
    For example:
    if
    enable_4 = '1' ;
    enable_3 = '1' ;
    enable_2 = '1' ;
    enable_1 = '0' ;
    enable_0 = '0' ;
    so
    configuration_sting = "FC"
    if
    enable_4 = '0' ;
    enable_3 = '1' ;
    enable_2 = '1' ;
    enable_1 = '0' ;
    enable_0 = '0' ;
    configuration_sting = "0C"
    Points: 61,891, Level: 60
    Apr 2014
    12,620
    61,891
    60
    Re: Converting an array of std_logic to string
    Hj,
    if
    enable_4 = '1' ;
    enable_3 = '1' ;
    enable_2 = '1' ;
    enable_1 = '0' ;
    enable_0 = '0' ;
    so
    Why "FC"? I'd expect "1C"
    (Corrected: "8C" --> "1C")
    I'd divide it into 4 bit nibbles.
    The values are 0...15
    For values of 0...9 you could add 0x30 to get values 0x30 ... 0x39 which are the ASCII values if "0" ..."9".
    For the other values add (0x41 - 0x0A) = 0x37 to get values 0x41 .... 0x46 which are "A" ... "F"
    •   AltAdvertisment
    Points: 36,169, Level: 46
    Jun 2010
    6,614
    36,169
    46
    Cant even be bothered to try yourself now?
    vhdl 2008 has to_string and to_hstring functions for all types, including std_logic_vector.
    •   AltAdvertisment
    Points: 245,674, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,684
    245,674
    100
    Do you have any specific question about writing the std_logic_vector_to_string() function?
    I presume you mean "1C" instead of "FC".
    TrickyDicky is right. to_hstring() does exactly what you want. You may want to copy the code if it isn't provided by your compiler/simulator.
    •   AltAdvertisment
    Aug 2011
    2,505
    12,407
    26
    I tried using the 2008 "to_string" function before posting...
    But as far as I understand (correct me if I'm wrong) - it wouldn't convert the "concatenated_enables" std_logic_vector to an ASCII hex string...it would leave it in a binary format.
    I guess this can be solved by writing a custom function that converts 4 binary nibbles into characters that represent the hex value - but I want to avoid this.
    My question is - how ?
    Jun 2010
    6,614
    36,169
    46
    use to_hstring instead.
  7. #7
    Aug 2011
    2,505
    12,407
    26
    You mean:
    hex_string := to_string ( enable_4 & enable_3 & enable_2 & enable_1 & enable_0) ;
    •   AltAdvertisment
  8. #8
    Jun 2010
    6,614
    36,169
    46
    constant configuration_sting : string := to_hstring(concatenated_enables );
  9. #9
    Aug 2011
    2,505
    12,407
    26
    Sorry, that's what I meant..
    Thanks.
    How well is this function supported with Vivado and Quartus?
  10. #10
    Jun 2010
    6,614
    36,169
    46
    No idea. Why dont you tell us?
