Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Points: 76,611, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,530
    76,611
    67
    Re: AMD or Intel for engineering PC?
    C_mitra speaks wisely. The CPU is only part of the issue so to a large degree the answer depends on the whole computer architecture. Also bear in mind that PCs are general purpose computers and run a wide variety of operating systems and programs so a direct comparison is difficult. When I hear people singing the praises of AMD though, they use their computers almost entirely for gaming, not engineering and I think the AMD chips are optimized in that direction rather than across a broader range of uses. Personally, I'm staying with Intel on all my 'work' machines although I do have an AMD based laptop (given to me by someone who gave up with it and upgraded to Intel!).
    Running Ubuntu or Kubuntu 18.04 on all machines.
    •   AltAdvertisment
  2. #22
    Points: 12,117, Level: 26
    Apr 2014
    1,890
    12,117
    26
    My friends at IMST run a large simulation cluster for electromagnetic analysis using both Intel and AMD machines. For entry level CPUs, they like the AMD Ryzen for its performance/cost ratio.
    •   AltAdvertisment
  3. #23
    Full Member level 4
    Points: 2,659, Level: 12
    Nov 2009
    Pakistan
    197
    2,659
    12
    AMD processors are quite prone to dusty and hot temperature. And from where you belong, it is better to use Intel Processor in your PC. Increase your RAM to 16GB and use hard disk with good data transfer rate
    •   AltAdvertisment
  4. #24
    Member level 3
    Points: 1,893, Level: 10
    Nik_2213's Avatar
    Jul 2010
    UK
    65
    1,893
    10
    At least with a lap-top you don't have to start with your graphics cards and work backwards !!
    FWIW, if you have ample RAM and core threads, you can add an external USB graphics module and display to side-step several work-flow issues...
  5. #25
    Full Member level 4
    Points: 1,802, Level: 9
    Aug 2014
    Buenos Aires, Argentina
    214
    1,802
    9
    Thank you for your responses.
    Finally I got an Intel I5 7200U. Running with a sataIII SSD disk and Windows 10 64 bit, I have a really good experience, very fast response and 20 seconds to boot.
    When I use VM for Linux the RAM fills up to nearly 70%, glad I bought the 8GB version PC. It's been 4 months now using it, and everything is going ok.
    •   AltAdvertisment
  6. #26
    Points: 15,446, Level: 29
    Nov 2012
    2,844
    15,446
    29
    Glad to know that you are happy with your new laptop.
