Results 1 to 14 of 14
    Points: 568, Level: 5
    Jun 2016
    35
    568
    Verilog error , Pls help
    I want to say thank you for guys which is always help me and others, and spent their time, based on this our world going to be better.
    I am know nothing in Verilog, here should be problem related to FPGA chip, because when i change to Virtex-4 from Spartan-6, there always error not declared :
    ERROR:HDLCompilers:28 - "TestCapture.v" line 26 'real_data' has not been declared
    ERROR:HDLCompilers:28 - "TestCapture.v" line 27 'pixel_fg' has not been declared
    But when I change to Spartan-6 thats ok. Could someone tell me what to do ?
    This project taken from https://github.com/zafartahirov/back...ubtract_XILINX
    `timescale 1ns / 1ps
    `define IDLE					0
    `define WAIT_4_NEW_FRAME	1
    `define RECORD_IMAGE			2
    `define PROCESS_IMAGE		3
    module test_buffer(
    	input [4:0] pixel_in,
    	output [4:0] pixel_out,
    	input [30:0] hCounter_in,
    	input [30:0] vCounter_in,
    	input clk
    	wire [4:0] pixel_temp;
    	wire blank_bg, blank_fg, blank_real;
    	assign blank_bg 	= (hCounter_in >= 640 | vCounter_in >= 480);
    	assign blank_real = 	hCounter_in < 170 | hCounter_in >= 330 | vCounter_in >= 140;
    	assign blank_fg	=	hCounter_in < 340 | hCounter_in >= 500 | vCounter_in >= 140;
    assign pixel_out =  ( {16{~blank_bg}} & pixel_temp ) |
                        ( {5{~blank_real}} & real_data ) |
                        ( {5{~blank_fg}} & {5{pixel_fg}}   );
    reg [14:0] counter_address, counter_address_real, counter_address_fg;
    reg wea = 1;
    reg [12:0] proc_d;	// processed data from BRAM
    wire [14:0] addr_write = (counter_address==0)? 22399: counter_address-2;	// computes the address of the BRAM
    reg [12:0]temp_bg;	// computed background (going to the BRAM)
    reg [4:0] temp_real;	// input from the camera
    reg [4:0] real_data;	// output of the camera feed
    reg temp_fg;				// the difference (goes to the BRAM)
    reg pixel_fg;	// the difference for foreground detection
    wire [4:0] difference;
    assign pixel_temp={temp_bg[11:7]};	// background output pixel
    assign difference[4:0] = (temp_real[4:0] > pixel_temp[4:0]) ?
    											(temp_real[4:0] - pixel_temp[4:0]) :
    											(pixel_temp[4:0] - temp_real[4:0]);
    always @(posedge clk) begin
    	// compute the current address for the BG detection
    	// as well as real feed
    	if (~blank_bg) counter_address <= counter_address+1;
    	if (counter_address >= 22399) counter_address <= 0;
    	if (~blank_real) counter_address_real <= counter_address_real+1;
    	if (counter_address_real >= 22399) counter_address_real <= 0;
    	if (~blank_fg) counter_address_fg <= counter_address_fg+1;
    	if (counter_address_fg >= 22399) counter_address_fg <= 0;
    end
    always @ (posedge clk) begin
    	if (~blank_bg) begin
    		temp_bg[12:0] = 	proc_d[12:0] 	- proc_d[12:7] 	+ pixel_in[4:0];
    		temp_real = pixel_in;
    		temp_fg =(difference[4:0] > 5);
    	end
    end
     //stores computed background
    buffer_data1  buffer_data (
        .clka(clk),
        .wea(wea),
        .addra(addr_write),
        .dina(temp_bg),
        .clkb(clk),
        .addrb(counter_address),
        .doutb(proc_d)
    // stores real feed
    bram_current_frame buffer_data_real(
    	 .clka(clk),
        .wea(wea),
        .addra(addr_write),
        .dina(temp_real),
        .clkb(clk),
        .addrb(counter_address_real),
        .doutb(real_data)
    // stores the difference frame
    bram_fg buffer_data_fg(
    	 .clka(clk),
        .wea(wea),
        .addra(addr_write),
        .dina(temp_fg),
        .clkb(clk),
        .addrb(counter_address_fg),
        .doutb(pixel_fg)
    endmodule
    •   AltAdvertisment
    Points: 29,150, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    Re: Verilog error , Pls help
    Both read_data and pixel_fg are declared after lines 26 and 27. They are declared on line 39 and 40 respectively.
    Embedding signal declarations within the functional code instead of only after the module port declarations is a bad coding practice IMO.
    Lines 31-43 should be inserted at line 19.
    Points: 245,688, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,684
    245,688
    100
    The verilog file is apparently corrupted, order of text lines has been confused. Place the respective lines below the variable definition, not above.
    I think it, to import the project successfully, you should have at least a basic understanding of Verilog language. With this background, you can easily find the problem yourself.
    Will it be accepted by any Verilog tool?
    Full Member level 5
    Points: 1,994, Level: 10
    Nov 2013
    Germany
    268
    1,994
    10
    Quote Originally Posted by abimann View Post
    `define IDLE					0
    module test_buffer(
    	input clk
    reg wea = 1;
    end
    	end
    end
        .clka(clk),
        .wea(wea),
        .addra(addr_write),
        .dina(temp_bg),
        .clkb(clk),
        .doutb(proc_d)
    // stores real feed
    	 .clka(clk),
        .wea(wea),
        .addra(addr_write),
        .dina(temp_real),
        .clkb(clk),
        .doutb(real_data)
    	 .clka(clk),
        .wea(wea),
        .addra(addr_write),
        .dina(temp_fg),
        .clkb(clk),
        .doutb(pixel_fg)
    endmodule
    how is it possible that you could pull it off with Spartan-6? did you check the settings? as ads-ee suggested you can declare the variables earlier and also move the "assign" blocks down
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    Quote Originally Posted by sreevenkjan View Post
    This is Xilinx tools we are talking about. Xilinx defaults to copying all your HDL code into it's own managed directories, so undoubtedly the OP has different files being compiled for the code for Spartan 6 and the Virtex 4.
    Advanced Member level 3
    Points: 5,356, Level: 17
    Feb 2015
    887
    5,356
    17
    There are several issues with this file. There is the obvious use of these values before being declared. This isn't actually an error until they are declared as they do eventually connect to module instance ports. (Verilog has a feature where nets can be implicitly declared as 1 bit wires if they connect to a module instance port. This behavior can also be disabled with `default_nettype none)
    But when proc_d, real_data, and pixel_fg are declared, they are specified as "reg". But then they are connected to module instance output ports, which should also be an error.
    There appears to be blocking assignments in one of the always blocks, which might cause issues. It also looks like addr_write can go from 22399 to 32767 to 0.
    •   AltAdvertisment
  7. #7
    Jun 2016
    35
    568
    Dear all , i made screenshot , brams are made for Virtex-4 not for Spartan6.Click image for larger version.
ID:	145575 this exactly based on fpga chip error
  8. #8
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    See post #5. I already explained that you probably have the file in a directory managed by the tools, so yes the files are probably different for the two different projects. The one in the Spartan directory is correct the one in the Virtex 4 directory is wrong.
  9. #9
    Full Member level 5
    Nov 2013
    Germany
    268
    1,994
    10
    if you have a look at my post #4, I suggested to check the settings, in this case I would suggest you to choose appropriate FPGA and then compile the project. you cannot have 1 device and compile the project meant to be for another device. It does not work like that.
  10. #10
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    I think you are overlooking the fact that the OP's errors are due to compilation errors in the file TestCapture.v (a file that is present in both projects). The file shows an error in the Virtex 4 project most likely due to using a local project file that was modified from the one used in the Spartan6 project.
    Which is a good reason to avoid using Xilinx's GUI and script your flow.
  11. #11
    Full Member level 4
    Points: 1,856, Level: 10
    May 2014
    223
    1,856
    10
    Have you tried regenerating the ip
    and
    bram_current_frame buffer_data_real.
    I would not be surprised if something on the lower level such as Xilinx ip decided to register the output signal in one fpga and not on the other.
    Change reg to wire. See what happens.
    •   AltAdvertisment
  12. #12
    Jun 2016
    35
    568
    ads-ee, I use new directory create file and only copy sources, BRAM ips are generated for Virtex-4 only .. when i use wire instead reg it also error...
  13. #13
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    Are we supposed to guess!?
    You know the git repo has broken code too. I wonder if they used someone else's code to show the image.
  14. #14
    Feb 2015
    887
    5,356
    17
    @abimann: you should move the declarations to before where they are used. you should change the type from reg to wire. Both of these should be done. At this point, there should either be:
    1.) a different error. you did something wrong.
    2.) the same error with the same line number. you have the wrong file.
    3.) the same error with a different line number. you probably did something wrong.
    4.) it works.
