Results 1 to 4 of 4
    Member level 5
    Points: 973, Level: 7
    Feb 2015
    83
    973
    7
    Calibre PEX simulation results
    ok back again, after seemingly getting Calibre DRC, LVS to work, I ran PEX. It gave me no errors but when I simulate the testbench with the calibre PEX view, my waveforms don't look right. The circuit is an example one, ( 2 stage buffer), from the TSMC flow guide.
    I am using calibre from the cadence environment and in my view setup file have view type as maskLayout and create terminals if matching terminals exist on symbol.
    I am getting two warnings
    WARNING: [FDI3022] Not creating terminal VDD! in (buffer2 calibre) since matching terminal was not found on symbol.
    WARNING: [FDI3022] Not creating terminal GND! in (buffer2 calibre) since matching terminal was not found on symbol.
    Calibre View generation completed with 2 WARNINGs and 0 ERRORs. Please consult the CIW transcript for messages
    I didn't create a VDD and GND pin in my symbol view even though the schematic cell view below have those nets.
    •   AltAdvertisment
    Points: 50,996, Level: 55
    erikl's Avatar
    Sep 2008
    Germany
    8,017
    50,996
    55
    Re: Calibre PEX simulation results
    If you use Inherited Connections in layout, you should do so in schematic.
    I can't recognize in your crazy layout (pls. excuse this expression: it seems not clearly arranged, but correct) if your power supply connections are also substrate/well taps, but if so, they are far too far away from their MOSFETs, I think.
    •   AltAdvertisment
    Member level 5
    Feb 2015
    83
    973
    7
    Quote Originally Posted by erikl View Post
    yeah the layout was auto generated using the chip assembly router feature. I did that to save time and because I wanted to learn the flow with using this design kit and calibre along with it.
    My VDD pin has M1_NWELL_contact over it and my GND pin has M1_PSUB contact over it. You are saying there might be an issue because they are not close enough to the MOSFETs?
    I need to read up on inherited connections issue you mention. There is something obviously wrong with VDD and GND connections.
    •   AltAdvertisment
    erikl's Avatar
    Sep 2008
    Germany
    8,017
    50,996
    55
    Quote Originally Posted by tenso View Post
    Oh, that's why! For a manual layouter it looks terrible, but may be correct anyway.
    DRC would tell you, if not close enough. And the auto place & route tool should know about its necessary max. spacing - i.e. should know the DRC rules.
    Also see dick_freebird's contribution to this topic.
