Results 1 to 4 of 4
    Junior Member level 3
    Points: 1,039, Level: 7
    Apr 2013
    30
    1,039
    7
    Trace width calculation for metal clad PCBs
    Is there a standard/calculator available to calculate trace width for designing metal clad PCBs? Many calculators available online can only calculate trace width for FR4 PCBs based on the IPC standard. I understand that due to better thermal performance of metal clad PCB, the temperature rise of the trace will be less compared to FR4 PCB for the same amount of current, thus providing more current capacity. But is there a standard or a correlation (maybe a formula) available, with which we can translate the trace width values for FR4 PCB to metal clad PCB?
    •   AltAdvertisment
    Advanced Member level 3
    Points: 9,314, Level: 23
    cyberrat's Avatar
    Jun 2001
    In the sewers of the U.K.
    865
    9,314
    23
    Re: Trace width calculation for metal clad PCBs
    Have you tried the Saturn PCB calculator?
    Please do not PM me questions that are better asked in the PCB forum :)
    •   AltAdvertisment
    Apr 2013
    30
    1,039
    7
    Yes, I did try Saturn PCB calculator. In fact that was the first thing I tried. Saturn PCB Toolkit does not offer any specific method to calculate trace current for metal clad PCBs.
    •   AltAdvertisment
    Points: 12,220, Level: 26
    Feb 2010
    UNITED KINGDOM
    1,932
    12,220
    26
    You more or less have the trace with a plane very near, use that figure in Saturn and you should be ok as a start point, anything else you will have to measure and qualify yourself, hence why I use the IPC-2152 figures from Saturn.
