Results 1 to 2 of 2
    Newbie level 3
    Points: 42, Level: 1
    Feb 2018
    42
    Plug & Cable for 2 twisted TX/RX and 24V (<1A) supply >=IP56
    I am right now searching for a Plug & Cable to transmit on two wires UART/TTL with a very low rate (512bit/s) and supply with 24V (<1A) on another two wires.
    Simply using RJ-45 etc. as a plug wouldn't be possible as it should be in total quite durable and at least fulfil IP56.
    As there could be E-motors/pumps and other electronics in the surrounding I would search for one with 2 twisted pairs, which are also shielded separately.
    Could somebody recommend something (especially regarding the plugs)?
    Thanks already in advance for helpful comments/thoughts. :)
    •   Alt1st March 2018, 12:16
      advertising
    Points: 29,071, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,686
    29,071
    41
    Re: Plug & Cable for 2 twisted TX/RX and 24V (<1A) supply >=IP56
    Don't use TTL for a differential twisted pair use a normal differential standard. For a UART serial RS422 is normally used in noisy environments.
