Results 1 to 8 of 8
    Member level 3
    Points: 1,315, Level: 8
    Dec 2012
    63
    1,315
    8
    Compare vectors with threshold
    hi all
    i'v 2 std vectors (16 bit wide) and i need to compare them within threshold (4 bit wide).
    enable	 <= '1' when unsigned(DATA) <= ((DATA2)+("0000"&unsigned(THRESHOLD))) and
                                       unsigned(DATA) >= ((DATA2)-("0000"&unsigned(THRESHOLD))) else
    		       '0' ;
    i know there is a problem on the edges of the vector, for example:
    2>= 0-7
    any suggestion would be aprochiated
    Best
    Gil
    •   Alt25th February 2018, 15:28
      advertising
    Points: 36,062, Level: 46
    Jun 2010
    6,589
    36,062
    46
    Re: Compare vectors with threshold
    I dont really understand the problem. Please could you explain what the issue is. Your code sets enable to '1' when DATA is between the THRESHOLD values on DATA2.
    NOTE. Why is everything declared as std_logic_vector, and not unsigned? doing all these type conversions makes it harder to read and may end up giving you an RSI.
    •   Alt25th February 2018, 17:43
      advertising
    Member level 3
    Dec 2012
    63
    1,315
    8
    the problem is with negative numbers, for example:
    DATA = 4,
    DATA2 = 2
    THRESHOLD = 5
    •   Alt27th February 2018, 15:01
      advertising
    Jun 2010
    6,589
    36,062
    46
    Your problem is one of wrap around. The 2nd compare will wrap around to a very high unsigned number.
    Why not used the signed type instead to avoid this problem?
    Member level 3
    Dec 2012
    63
    1,315
    8
    Do you mean somthing like this:
    enable <= '1' when unsigned(abs(signed(DATA)-signed(DATA2)) < ("0000"&unsigned(THRESHOLD)) else '0'  ;
    •   Alt27th February 2018, 15:19
      advertising
    Jun 2010
    6,589
    36,062
    46
    Thats pretty hiddeous. WHats wrong with this:
    Code VHDL - [expand]
    enable   <= '1' when signed('0' & DATA) <= (signed('0' & DATA2)+(signed('0' & THRESHOLD))) and
                         signed('0' & DATA) >= (signed('0' & DATA2)-(signed('0' & THRESHOLD))) else
                   '0' ;
    Would be even better if DATA, DATA2 and THRESHOLD are signed data types in the first place. There is absolutly no need for them to be std_logic_vectors. Ports can be unsigned/signed.
  7. #7
    Member level 3
    Dec 2012
    63
    1,315
    8
    Hi
    i'v changed it so it can do the warp around:
    enable_riz	 		<= '1' when resize(signed(COMPA),COMPA'length +2)   <= (resize(signed(COMPB),COMPB'length +2)  +(signed('0' & th))) and
    								resize(signed(COMPA),COMPA'length +2)   >= (resize(signed(COMPB),COMPB'length +2)  -(signed('0' & th)))
    						   else '0' ;
    your code is:
    enable   	<= '1' when signed('0' & COMPA) <= (signed('0' & COMPB)+(signed('0' & th))) and
    							signed('0' & COMPA) >= (signed('0' & COMPB)-(signed('0' & th)))
    					   else '0' ;
    and the results are:
  8. #8
    Jun 2010
    6,589
    36,062
    46
    What is your question? You have only posted a snippet and a waveform with different signal names to what is in your code.
    Please ask a question and post the whole code if you have an issue.
