Results 1 to 8 of 8
    Junior Member level 1
    Points: 450, Level: 4
    Feb 2018
    17
    450
    [Moved]: How to remove glitches at the output of brown out detector?
    i have designed brown out detector circuit. it consists of current mirror +power on dealy+ brown out detector + comparator with hysteresis. but at the output i am getting glitches while power supply is rising and falling (appox. 3.75 us). i want to remove those glitches. can anyone tell me how to remove it?
    Points: 83,974, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,823
    83,974
    70
    Re: How to remove glitches at the output of brown out detector?
    Possibly with an RC filter and if necessary another comparator. You could also use monostables. There are several analog alternatives or you could do it with digital circuits to poll the signal and only change output after your detector is showing a stable output.
    Points: 81,979, Level: 69
    Apr 2014
    16,638
    81,979
    69
    Re: [Moved]: How to remove glitches at the output of brown out detector?
    Why remove? Why not avoid them by a redesign?
    Feb 2018
    17
    450
    How? what changes should i make?
    Advanced Member level 2
    Points: 4,804, Level: 16
    Pjdd's Avatar
    Jan 2011
    527
    4,804
    16
    Can you post a schematic of what you've designed so far?
    Feb 2018
    17
    450
    here is my schematic. i
  7. #7
    Pjdd's Avatar
    Jan 2011
    527
    4,804
    16
    Yikes! It's going t take some effort to reverse analyze that. Can you give a quick run-through of how it's supposed to work?
  8. #8
    Feb 2018
    17
    450
    Right side Vpor:
    When Vdd > vgs1+vgs2+vgs3: current will start flowing through M5 which will charge the capacitor(M6). And vourt will start tracking power supply. reset will be 1. as soon as capacitor charges till Vlow= Vd1+Vd2+Vgs4= 2V reset will be 0.
    when power supply goes down than Vlow M4 will turn off. M7 will pull Vctrl to the gnd. M8 will turn on,capacitor(M6) will discharge through M8 faster.
    left side of Vpo:
    r is comparator with hystersis. so it will compare two input and give output high or low.
    I put inverter after Vout because i required opposite output.
