+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 6
    Points: 156, Level: 2
    Join Date
    Dec 2017
    Posts
    14
    Points
    156
    Level
    temperature problem with mosfet
    I used a mosfet driver tc4422 to control a irf510.
    The problem i faced was how to connect it without damage
    Click image for larger version.
    I tried and it got to a high temperature
    •   Alt19th February 2018, 21:36
      advertising
  2. #2
    Points: 6,567, Level: 19
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    1,179
    Points
    6,567
    Level
    19
    Re: temperature problem with mosfet
    You have wrongly tuned the circuit then. You are not achieving ZVS.
    •   Alt19th February 2018, 22:49
      advertising
  3. #3
    Super Moderator
    Points: 244,817, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    42,523
    Points
    244,817
    Level
    100
    Without circuit parameters no switching loss calculation possible.
    •   Alt19th February 2018, 23:27
      advertising
  4. #4
    Advanced Member level 3
    Points: 6,257, Level: 18
    Join Date
    Aug 2015
    Posts
    981
    Points
    6,257
    Level
    18
    the circuit appears to be missing a diode?
  5. #5
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    1,179
    Points
    6,567
    Level
    19
    Quote Originally Posted by Easy peasy View Post
    No. That is why "Cp" is there.
  6. #6
    Join Date
    Aug 2015
    Posts
    981
    Points
    6,257
    Level
    18
    Cp is already in parallel with a diode ( the mosfet) for DC in the load another diode is needed...
    •   Alt25th February 2018, 19:59
      advertising
  7. #7
    Advanced Member level 5
    Points: 35,848, Level: 46
    Join Date
    Mar 2008
    USA
    Posts
    5,765
    Points
    35,848
    Level
    46
    I'd begin with what the uC is doing - its on-time is the only
    first-order limit to the current through FET and boost inductor.
    When you have that sorted, then look to your heat sink
    (and -its- heat sink, airflow etc.).
  8. #8
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    1,179
    Points
    6,567
    Level
    19
    I think he does not want DC in the load in a resonant sine wave inverter.
    https://eprints.qut.edu.au/62445/3/P...227_singer.pdf
