Results 1 to 6 of 6
    Points: 351, Level: 4
    Nov 2017
    48
    351
    equivalent circuit of tranformer referred to secondary?
    Hello Everyone,
    I would like to understand why when we do the equivalent circuit of transfer referred to scondary we multiply the imedance of the primary by N°2. the voltage mltiplied by N , current divided b N and vice versa when referred to the primary?
    best regards
    •   AltAdvertisment
    Points: 11,941, Level: 26
    Apr 2010
    1,830
    11,941
    26
    Re: equivalent circuit of tranformer referred to secondary?
    to make the analysis/calculation simpler.
    •   AltAdvertisment
    Full Member level 1
    Points: 844, Level: 6
    Aug 2016
    Bangalore, India
    103
    844
    Quote Originally Posted by tarikelec View Post
    Hello Everyone,
    best regards
    Because that's how you relate the parameters (viz. voltage, current and impedance) of primary to the secondary.
    •   AltAdvertisment
    Points: 61,937, Level: 60
    Apr 2014
    12,624
    61,937
    60
    What else do you expect?
    What exactly is the problem?
    Nov 2017
    48
    351
    I want to know how did the equations and the formulas are derived from the transformer to its equivalent circuit step by step because when I look at it in teh litereture I don#t understand how did they come to the result
    •   AltAdvertisment
    Points: 27,344, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,181
    27,344
    40
    Blog Entries
    The formulas are derived from laws governing physical phenomena (Faraday, in this case) and also from premises (the magnetic flow passing through the secondary arm is ideally equal to the one of the primary). The rest is purely mathematical development, but this is well documented on the Web in greater or lesser depth of details. Anyway, as stated above, it is a matter of simplification; if we are analyzing a particular part of a circuit, we have to reduce the remainder that is not the focus of attention to a simpler model. The classic example is when we simulate the load at the output of this transformer only by a resistor, although it is effectively a complex circuit.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
