Results 1 to 4 of 4
    Newbie level 2
    Points: 991, Level: 7
    Oct 2012
    991
    7
    Orthogonal space time block codes
    Hello
    Alamouti scheme (amongst others) is said to be an orthogonal STBC. What I don't understand is the "orthogonal" part. WHAT exactly is orthogonal? Can somebody show me mathematically how it is orthogonal? I've tried using the orthogonal matrix definition (matrix times its transpose = identity matrix) with no luck.
    •   Alt9th February 2018, 12:54
      advertising
    Advanced Member level 3
    Points: 6,079, Level: 18
    Jul 2010
    Sweden
    787
    6,079
    18
    Re: Orthogonal space time block codes
    Orthogonal means that they don't affect each other. When you decode using one code, all other orthogonal codes present before the decoding cancel out, so they don't have any effect on the result after decoding.
    •   Alt9th February 2018, 15:41
      advertising
    Newbie level 2
    Oct 2012
    991
    7
    I understand that orthogonality allows the symbols to be uniquely decoded (i.e. they dont interfere with each other) but how do you tell if a scheme is orthogonal or not?
    How would you show that [x1 x2; -x2* x1*] is an orthogonal scheme?
    •   Alt9th February 2018, 16:42
      advertising
    Jul 2010
    Sweden
    787
    6,079
    18
    Orthogonality means that the dot product is zero.
    [x1 x2] is orthogonal to [ -x2* x1*] because x1(-x2*) + x2(x1*) = 0
