Results 1 to 5 of 5
    Points: 299, Level: 3
    Nov 2017
    42
    299
    what are the value I should put in PID controller of simulink and PLECS?
    Hello everyone,
    As I am trying to control a DC/DC converter, I am bit confused about the parameters of the PID. so I will ask these stupid questions.
    1-in simulink, I find the the variable to fill in the PID(z) Controller as P. I , and D. here I am bit confused ,should I write Ku(ultimae gain) in the box P, Ti in box I and Td in box D or Kp, Ki and Kd.
    2-in PLECS, trhe same problem arised as in the PI COntroller I found in one of their demos,Ki and Kp, what are these value representing? is it Kp and Ki(Ki=kp/Ti) or just Ti?
    thnak you so much for clarifying me#
    cheers
    •   Alt7th February 2018, 16:21
      advertising
    Points: 6,367, Level: 19
    Dec 2015
    Madrid, Spain
    1,135
    6,367
    19
    Re: what are the value I should put in PID controller of simulink and PLECS?
    I am not aware of any PID controller block in PLECS, can you share how/where did you find it ?
    When you open the PID(z) block you can see how it is implemented. You need to insert the latter option you mentioned.
    •   Alt7th February 2018, 17:56
      advertising
    Points: 15,897, Level: 30
    E-design's Avatar
    Jun 2002
    2,014
    15,897
    30
    I think the PID is available in the later versions of PLECS. It is not available in my old version.
    https://www.plexim.com/support/application-examples/187
    •   Alt7th February 2018, 18:19
      advertising
    Dec 2015
    Madrid, Spain
    1,135
    6,367
    19
    Quote Originally Posted by E-design View Post
    The example you showed is called (at least in my version) "Buck Converter with loop gain Analysis". You can find it under demo models --> Power supplies.
    The "PID controller" block is simply a subsystem, not a block per se.
    Full Member level 6
    Points: 2,774, Level: 12
    Feb 2014
    338
    2,774
    12
    I'm not familiar with PLECS specifically but in my experience although the term "PID" is widely used there is nothing close to a standard implementation of "PID" or its coefficients (there are many ways to arrange the PID blocks, scale the coefficients, etc).
    So the right approach is to decide what you want the PID to do in terms of its frequency response. Then use the AC/frequency domain simulation (which PLECS appears to have) to verify that your specific PID implementation and coefficients are doing that. Don't just trust the documentation and a stable closed loop also doesn't guarantee its doing what you want.
    As another aside while P, I and D blocks can be combined to meet almost any control requirement (and discrete PID blocks are currently my preferred digital control solution versus, say, biquad IIRs) I'm aware of no systems where a single P, I and D (two zeros and one pole) is an ideal compensation solution. So its perplexing to me that PID is presented as such a common and general control scheme.
