+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 1
    Points: 29, Level: 1
    Join Date
    Jan 2018
    Kraków
    Posts
    Points
    29
    Level
    Cost Effective Banana Jack Solution
    I am trying to come up with a low cost - and no tooling solution to adding a vertical banana jack to my PCB. No tooling because I'm starting with a small batch. But I hope to ramp up; so, it should be scalable too. I might find a dedicated connector that works but that would greatly constrain the height of my enclosure and if the connector is later not available I would be screwed.
    Any solutions need to be round with 4mm+0.15/-0.05 ID and <=6mm OD. The OD limit allows the guard of a "safety" plug to go over it. The ID tolerances are a rough estimate.
    The ideal solution would be a nickel plated, round brass spacer attached with a thread rolling screw. But I haven't found any off-the-shelf solutions with the correct inner diameter. How much would a custom spacer cost? ...with what minimum quantity?
    Another solution might be a brass tube cut to length. These tubes seem to be readily available in the correct dimensions. But is bare brass a good choice? What about corrosion? Is nickel plating a viable option for my low budget, low quantity needs?
    Any relevant thoughts on this would be appreciated!
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 24,282, Level: 37
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    4,656
    Points
    24,282
    Level
    37
    Re: Cost Effective Banana Jack Solution
    Not sure what you mean by "no tooling". Drilling a hole is tooling. You could just put a plated through hole the right size for a banana plug in the PCB. Depending on your chassis material, and physical dimensions, you might have to put some kind of backing plate some distance behind the PCB to limit the plug insertion depth.
    •   AltAdvertisement
  3. #3
    Super Moderator
    Points: 52,941, Level: 56
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    12,948
    Points
    52,941
    Level
    56
    I'm pretty sure I saw one of my digital meters having banana jacks attached directly to the board. Made from metal tubing, inexpensive, with bendable tabs at one end. The assembler pushes the tabs through slots in the board, then bends them. The jack locks itself to the board, ready to solder. The plastic enclosure is molded to surround the tube, so it cannot be pushed or pulled, or bent at an angle. Thus the PCB is not stressed.
    It should be easy to fabricate from a section of collapsible antenna.
    1 members found this post helpful.
    •   AltAdvertisement
  4. #4
    Advanced Member level 3
    Points: 9,635, Level: 23
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    889
    Points
    9,635
    Level
    23
    Try google images.
    Then you get to pick one and find it :)
    Please do not PM me questions that are better asked in the PCB forum :)
  5. #5
    Newbie level 3
    Points: 33, Level: 1
    Tunalover's Avatar
    Join Date
    Feb 2018
    Plymouth, MI and Lancaster, NY
    Posts
    Points
    33
    Level
    Go to any electronics distributor like DigiKey, Allied Elec, McMaster-Carr, Newark Elec. They all will have panel mount banana jacks with solder terminals for wire connectins. If you want the banana jack to connect with the PCB then I' sure they are available in a solder style or other design that has intimate contact with plated-through holes on the PCB.
    Tunalover
    A mechanical guy
