Results 1 to 8 of 8
    Points: 1,109, Level: 7
    Apr 2013
    35
    1,109
    7
    Orcad Capture Simulation of Voltage Controlled Mode Buck converter
    Hello all,
    I am having trouble simulating a comparator. Please see the image of the circuit.
Name:	Voltage mode controlled buck.jpg
    The circuit converges upto 40useconds only. Even then it does not work properly.
Name:	Comparator output.jpg
    Please help me with the simulation of the comparator.
    Thanks.
    •   Alt5th January 2018, 19:59
      advertising
    Points: 243,627, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,318
    243,627
    100
    Re: Orcad Capture Simulation of Voltage Controlled Mode Buck converter
    LM741 isn't suited for single supply operation and not specified for 5V supply at all. Redesign with reasonable parameters.
    I also won't expect useful output from a PI controller without closing the feedback loop.
    Apr 2013
    35
    1,109
    7
    Problem in Simulation of Voltage Mode Control
    Hello all,
    This is my second post. I am new to all topics in Power Electronics. I have simulated a Voltage Mode controlled Buck Chopper.
Name:	Pspice VMC Buck.jpg
    Unfortunately the controller only seems able to handle changes in output current but not changes in input voltage. This is seen in the next image.
Name:	Output of VMC Buck.jpg
    Could anyone please tell me what I am doing wrong.
    Thankyou.
    Shomik C
    Last edited by BradtheRad; 14th January 2018 at 08:25. Reason: Condensed two similar posts
    •   Alt14th January 2018, 06:45
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,318
    243,627
    100
    Re: Problem in Simulation of Voltage Mode Control
    I don't understand how you arrived at the strange controller design. What's the reason behind dividing the process value and set point to a low mV voltage? How do you expect a stable output voltage without an integral term in the transfer function?
    Apr 2013
    35
    1,109
    7
    Dear Sir,
    Dear Sir, Thankyou for the reply.
    Please forgive me on my ignorance. As I am completely new and working on my own I am facing problem with basic issues which experienced persons might assume to be just common sense.
    I thought that dividing the reference value to a low mV input for error amplifier will lead to low mV output of the error amplifier which is then the input for the compensator amplifier which has the positive terminal grounded. And from books I read that the op amp to work in linear range with amplification the difference between the two inputs has to be very small.
    Also I thought having a capacitance of 100pF will give me the integral term.
    Thankyou.
    Apr 2013
    35
    1,109
    7
    Sir,
    Thank you.
    As soon as I put the capacitance in series with the resistor the output of the op-amp of the controller goes into saturation.
    And also input voltage perturbation with my circuit shown is not handled only load current variations seem to be handled properly.
    Thank you.
    •   Alt14th January 2018, 11:15
      advertising
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,318
    243,627
    100
    A typical error amplifier + compensator is implemented with a single OP, look at popular PWM controller ICs or text book schematics.
    The main disadvantage of voltage downscaling is the increasing error due to OP offset voltage. Apart form this point, it should work. Having a controller transfer function with integral term is however mandatory to avoid a stationary error. A popular PI transfer function is generated by putting the integrator capacitor in series with a resistor. Proportional and integral gain can be adjusted separately by changing both values.
    Now you have a pure P controller with an additional low pass corner at 230 kHz, far beyond feasible control loop bandwidth.
    Doesn't make sense. What you probably see is the control amplifier saturated with constant pwm duty cycle and no control action at all.
    As a first step, you may want to reduce the inverting amplifier gain from 150 to below 1 so that the integrator output range doesn't exceed the linear pwm range by a huge factor. Or more generally, design controller parameters by calculation instead of choosing it arbitrarily.
  8. #8
    Apr 2013
    35
    1,109
    7
    Ok Sir,
    Thank you. I will try that. Your input has been very helpful.
