Results 1 to 5 of 5
    Advanced Member level 2
    Points: 3,934, Level: 14
    Apr 2011
    541
    3,934
    14
    What determines the number of rows in an SDRAM?
    SDRAM is divided into banks, each bank into rows and each row into columns. What determines how many rows will be there in an SDRAM?
    Is there a formula used to go from a single memory location address to generate three addresses of bank, row and column?
    •   Alt5th January 2018, 10:57
      advertising
    Points: 244,846, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,531
    244,846
    100
    Re: What determines the number of rows in an SDRAM?
    The DRAM chip internal organisation. Review the datasheet.
    •   Alt5th January 2018, 12:35
      advertising
    Apr 2011
    541
    3,934
    14
    So it is an arbitrary choice of the SDRAM designers? I see.
    •   Alt5th January 2018, 16:58
      advertising
    Full Member level 1
    Points: 826, Level: 6
    Aug 2016
    Bangalore, India
    103
    826
    But if you can access memory locations using linear addressing, then internal organisation may not matter for your application.
    Points: 36,062, Level: 46
    Jun 2010
    6,589
    36,062
    46
    Quote Originally Posted by mjuneja View Post
    It can be very important. DRAM can be very slow when switching from row to row. But reading across banks and within a row incurs little/no turnaround penalty. So if you can, it is best to design your logic with this knowledge.
