Results 1 to 11 of 11
    Junior Member level 3
    Points: 248, Level: 2
    Oct 2017
    31
    248
    non responsive vhdl code in FPGA board
    I wrote a VHDL code for synchronous demodulation. I use vivado 2016.4. it works perfectly with a testbench in the software. but when I burnt the code into the FPGA board (Xilinx Artix-35T FPGA (xc7a35ticsg324-1L)) it doesnt work. any suggestions?
    I used a software called terra term to read the output from the board. it is serial communication. nothing is wrong with the board. I tested the board with a different code and it worked. since it works fine in the simulation i couldnt find the error in my code.
    the baud rate and pin mapping are double checked and verified. plus after implementing the design I ran a post-implementation timing simulation also. the result was positive. it said the user timing constraints are completely met.!! need help!
    Points: 61,891, Level: 60
    Apr 2014
    12,614
    61,891
    60
    Re: non responsive vhdl code in FPGA board
    Possible issues:
    Not correct power supply
    No valid clock source
    Wrong schematic
    Wrong code
    Wrong expectation
    Wrong test method
    If you want us to validate your application you need to give all these informations.
    •   AltAdvertisment
    Oct 2017
    31
    248
    thank you for replying. but as I mentioned, it is working properly with a testbench. so I hope the code is ok. at least there is no error in the synthesis. and from the post-implementation time simulation, it gave a positive reply. it said the user timing constraints are met. and about the power supply, the board is connected to my lap! i mean if thats what you meant by incorrect power supply.
    i didn't understand what u mean by wrong expectation and test method!
    •   AltAdvertisment
    Points: 36,169, Level: 46
    Jun 2010
    6,614
    36,169
    46
    What do you mean by "working properly in a testbench"?
    Have you tested it exhaustively?
    Have you modelled all the busses?
    Did it pass all your asserts?
    Have you used appropriate coding styles?
    Did the design meet timing?
    In your case, the usual issue is poor coding. It is easy to write code that will "work" in a testbench and then fail synthesis because you didnt use correct coding styles. Why no post the code so we can help?
    •   AltAdvertisment
    Oct 2017
    31
    248
    no synthesis error and timing constraints are met.
    i ll upload the code below:
    in this code, the period of CLK is 20ns and demod_clk is 1320ns
    TX_DATA and RX_DATA are set of 24 data points which are 32767,40609,47995,54496,59735,63406,65296,63406,59 735,54496,47995,40609,32767,24924,17538,11037,5798 ,2129,238,2129,5798,11037,
    17538,24924
    TX_DATA is the refference wave and RX_DATA is the incoming wave. i am using same numbers for both for the sake of verification.
    entity scheme_demod is
        Port ( TX_DATA : in signed(16 downto 0);
               RX_DATA : in signed(16 downto 0);
               clk : in std_logic;
               demod_clk : in  STD_LOGIC;
    	       --rx_data_compl : in std_logic;
    		   tx_data_compl : in std_logic;
    		   b_count : out std_logic;
    		   start_data : out std_logic;
    		   start_data1 : out STD_LOGIC;
    		   DATA_OUT : out std_logic_vector (39 downto 0)
    end scheme_demod;
    architecture Behavioral of scheme_demod is
    type bus_type is array(0 to 23) of integer range 0 to 65535;
    type bus_type1 is array (0 to 23) of signed (16 downto 0);
    signal temp_rx : bus_type1 :=(others =>(others => '0'));
    signal temp_tx : bus_type1 :=(others =>(others => '0'));
    signal newrx : bus_type1 :=(others =>(others => '0'));
    signal i,p : integer :=0;
    signal moore_rx : signed (16 downto 0);
    signal new_rx : signed (16 downto 0);
    signal dif : signed (16 downto 0);
    signal temp_sum : signed(39 downto 0) :="0000000000000000000000000000000000000000";
    signal a,b : std_logic;
    signal zc_clk,demod : std_logic;
    signal test,test1 : std_logic := '1';
    begin
    start_data <= test;
    start_data1 <= test1;
    process(demod_clk,clk)
    begin
      if rising_edge(demod_clk) then
        test <= '1';
        temp_tx(i) <= TX_DATA - 32767;
        temp_rx(i) <= RX_DATA - 16384;
        moore_rx <= temp_rx(i);
        i <= i + 1;
      end if;
      if rising_edge(clk) then
       dif <= 0 - moore_rx;
       if (0 - moore_rx > 0) then
            a <= '0';
        else a <= '1';
        end if;
        end if;
      if rising_edge (demod_clk) then
        b <= a;
        end if;
     if i = 24 then i <= 0; end if;
     end process;
    zc_clk <= (not b) and a;
    process(zc_clk,demod_clk)
    variable k : integer:=0;
    begin
    if zc_clk' event and zc_clk = '1' then
     demod <= '1';
     k := 1;
     end if;
      if falling_edge(demod_clk) then
        if demod = '1' then
    --        b_count <= '0';
            newrx(k) <= moore_rx;
            new_rx <= newrx(k);
            temp_sum <= temp_sum + newrx(p) * temp_tx (p);
            p <= p + 1;
            k := k+1;
       end if;
       end if;
      if k = 24 then
         k :=0;
      end if;
          b_count <= '0';
        if  p = 24 then
            b_count <= '1';
           DATA_OUT <= std_logic_vector(temp_sum);
           temp_sum <= "0000000000000000000000000000000000000000";
            p <= 0;
         end if;
     end if;
     end process;
    end Behavioral;
    Points: 245,674, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,678
    245,674
    100
    No fun to be proved right...
    About to impossible for various asynchronous constructs like
    outside an edge sensitive condition.
    My general suggestion is to rewrite the code in a strictly synchronous manner, everything under the control of the 50 MHz clock, external events synchronized to it as far as necessary.
  7. #7
    Points: 29,150, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    I would also suggest using 1 clock 1 process, instead of 2 clocks 1 process.
    I guess synthesis tools have gotten better if it didn't barf on that coding style.
  8. #8
    Full Member level 1
    Points: 844, Level: 6
    Aug 2016
    Bangalore, India
    103
    844
    Too many clocks in a single process.
    I would recommend define your process in a way that makes your code synthesizable.
    A reference template has been added for your reference.
    process (<clock>,<async_reset>,<en>)
    begin
       if <async_reset> = '0' then
          <statements>;
       elsif (<clock>'event and <clock> = '1') then
          if <en> = '0' then
             <statements>;
          else
             <statements>;
          end if;
       end if;
    end process;
  9. #9
    ads-ee's Avatar
    Sep 2013
    USA
    6,721
    29,150
    41
    en in the above code is not required and should not be in the sensitivity list. It will actually cause the simulator to reenter the process when en changes wasting simulation kernel cycles.
    clock'event and clock = '1' is depricated over using the function rising_edge(clock), this antiquated style (with actual simulation repercussions) is taught by way too many academic institutions. You would think a institution of higher learning would learn what is new (actually very old) in a language.
    •   AltAdvertisment
  10. #10
    Full Member level 1
    Aug 2016
    Bangalore, India
    103
    844
    Quote Originally Posted by ads-ee View Post
    I agree that for simulation it will impact but if we look in terms of synthesisability of the code that won't matter.
    Yes, then we can replace clock'event and clock = '1' with rising_edge(clock) in the template to ensure '0' to '1' transition.
  11. #11
    Jun 2010
    6,614
    36,169
    46
    Quote Originally Posted by mjuneja View Post
    I agree that for simulation it will impact but if we look in terms of synthesisability of the code that won't matter..
    No, it wont (and in reality, unlikely to impact simulation much as Im sure the optimisation processes will catch this), but it comes down to good coding practice. Adding extra signals to sensitivity lists can be confusing for other users.
