+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 66, Level: 1
    Join Date
    Dec 2017
    Posts
    Points
    66
    Level
    Novel method in Compensation for Op-amp
    Hello,
    I was reading through compensation methods for 2 stage CMOS op-amps which include 3 methods:
    1. Nulling resistor
    2. Put Source follower with Miller Cap
    3. Common Gate with Miller Cap (aka Ahuja Compensation http://ieeexplore.ieee.org/stamp/sta...number=1052012)
    My question is -To Block the FeedForward path why not simply use a diode, say instead of Souce Follower? See the pic for more clarity...Any reasons why it won't work?Click image for larger version.
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 51,733, Level: 55
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    8,079
    Points
    51,733
    Level
    55
    Re: Novel method in Compensation for Op-amp
    FeedForward path means a signal path, an ac path!
    •   AltAdvertisement
  3. #3
    Full Member level 1
    Points: 1,746, Level: 9
    Join Date
    Oct 2012
    India
    Posts
    102
    Points
    1,746
    Level
    9
    Hi analog_wiz,
    Quote Originally Posted by analog_wiz View Post
    I think you meant Common Source stage with Miller Cap.
    I think the goal (in Ahuja Comp) was to remove the feed forward path from 1st stage to 2nd stage but still have a miller compensation (or Cap multiplication).
    In you circuit isn't the diode blocking the Miller Cap ? The diode small signal equivalent model can be drawn when it is forward biased, how do you ensure in your ckt that the diode is DC forward biased ? Also it's small signal (ac) equivalent is nothing but a resistance so its'n it same as normal Miller (if at all one can keep it in forward bias)?
    What small signal (ac) behavior are you expecting from the diode ? Could you elaborate or show any result/derivation ?
    Let me know your comments.
    Thanks,
    Siddhartha
