sakkano2
Hello.
I need to design a single-phase Cmos op-amp as my homework.I try to design the circuit shown below and made calculations on it but when i simulate the circuit on LTSpice i get unwanted gain value.I try to make adjustements on Mosfet s to reach the desired gain of 20dB but i can not reach that value.Is there anything wrong with my circuit? and how can i reach 20dB gain. I will be very gratefull if you can help me.
My paramaters are;
Gain=20dB
Gain Bandwith = 1MHz
Supply Voltage = 2.5Volts
Power Budget=5mW
Load capacitance=100pF
I assume ICMR as -1 to 2 Volts , K'p =63uA , K'n=325uA , Vtp=-0.46V, Vtn=0.49.
With respect to these values i found W/L ratios and transconductance values.
and my Spice file is:
Thank you very much for your help.
Have a Good Day.
My paramaters are;
Gain=20dB
Power Budget=5mW
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 M2 Vout 0 N005 0 NMOS l=5u w=3u ad=96e-12 as=96e-12 pd=44e-6 ps=44e-6 m=1 nrd=1.0 nrs=1.0 M1 N002 N003 N005 0 NMOS l=5u w=3u ad=96e-12 as=96e-12 pd=44e-6 ps=44e-6 m=1 nrd=1.0 nrs=1.0 M4 N001 N002 Vout N001 PMOS l=4u w=5u ad=96e-12 as=96e-12 pd=44e-6 ps=44e-6 m=1 nrd=1.0 nrs=1.0 M3 N001 N002 N002 N001 PMOS l=4u w=5u ad=96e-12 as=96e-12 pd=44e-6 ps=44e-6 m=1 nrd=1.0 nrs=1.0 M5 N005 N004 0 0 NMOS l=1u w=2u ad=96e-12 as=96e-12 pd=44e-6 ps=44e-6 m=1 nrd=1.0 nrs=1.0 M6 N004 N004 0 0 NMOS l=1u w=2u ad=96e-12 as=96e-12 pd=44e-6 ps=44e-6 m=1 nrd=1.0 nrs=1.0 C1 Vout 0 100p I1 N001 N004 2m AC 1 V1 N003 0 SINE(0 2 1000) AC 1 V2 N001 0 2.5 AC 1 .model NMOS NMOS .model PMOS PMOS .lib C:\Users\Bugra\Documents\LTspiceXVII\lib\cmp\standard.mos ;tran 100 .ac dec 500 1 1000000 .backanno .end
Have a Good Day.
