T
treez
Large off-the-shelf power inductors shoudl not be used in products?
Hello,
Our engineering contractor wants to use the C1061-AL PFC inductor in a 150W PFC design..
C1061-AL PFC inductor:
We are convinced that such offtheshelf parts are only for single prototype units, and not for use in real products, since the part may well go obsolete, or become nil-stocked, (with a long lead time) do you agree?
If a PFC inductor is needed, then it should preferably use a standard offtheshelf core and former (eg ferroxcube PQ30 , ETD39, ETD54, etc etc). These standard formers and cores are standard and will never go obsolete, and will always be in-stock somwhere. Admittedly they need to be wound, and so it is effectively a custom part in the BOM, but that surely is better than using a part that has a high chance of going obsolete? After all, if one builds an enclosure round a part that goes obsolete, then the entire enclosure will likely need to be changed to accommodate whatever is found to replace the obsolete part.
Hello,
