Results 1 to 3 of 3
    Full Member level 6
    Points: 4,628, Level: 16
    Nov 2003
    Brazil
    388
    4,628
    16
    AC switch with DC control
    Dear sirs,
    I have a PLC with 12 x 127Vac inputs and need to be drived by 24V sensors. My first try was using relays but the sensors are very fast and run at +-10Hz so the stress of the relays will destroy then in a very short time. Was thinking to use one MOC3010 for each channel. According to the manufacturer of the PLC each input looks like the attached schematic. My idea is attached too.
    Any idea will be very usefull.
    Regards,
    Fernando
    •   AltAdvertisment
    Points: 61,937, Level: 60
    Apr 2014
    12,624
    61,937
    60
    Re: AC switch with DC control
    The PLC input current will be low.
    But according datasheet the MOCs are not made for directely drive some load.
    In your case a small SCR at the MOC output will rectify this.
    Did you consider to use an SSR or a photomos relay? like LH1546ADF
    •   AltAdvertisment
    Points: 13,655, Level: 28
    schmitt trigger's Avatar
    Apr 2013
    2,298
    13,655
    28
    Tocayo;
    it is best if you employ a solid state relay (SSR), which takes care of the details of driving a Triac from a logic line.
    My batteries are recharged by "Helpful Post" ratings.
