Results 1 to 8 of 8
    Newbie level 2
    Points: 24, Level: 1
    Dec 2017
    24
    What is a standard Stack-up for 6L PCB?
    I'd like to optimize this kind of stackup suitable to make Click image for larger version.
    It's 3 Fr4 and 2PP,and It's not symmetry, It's better for 3 PP, 2Fr4, and make the thickness same.it will be easer to make and reduce your cost.
    Last edited by bassa; 7th December 2017 at 07:49. Reason: Update the post contents
    •   AltAdvertisment
    Full Member level 4
    Points: 3,758, Level: 14
    senilicus's Avatar
    Feb 2007
    Amsterdam / The Netherlands
    233
    3,758
    14
    Re: What is a standard Stack-up for 6L PCB?
    You should ask you'r PCB manufacturer, he knows his materials.
    But as a guide you can use something like this;
    Points: 245,688, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,688
    245,688
    100
    There's no single standard stack-up. At best, PCB manufacturers have a preferred stack-up for general purpose boards that are e.g. made in a production pool. You can browse respective manufacturer web sites, like this http://www.pcb-specification.com/uk
    You can presume that a "standard" 6L board is made with two cores. Copper weight, substrate and prepreg thickness vary depending on application requirements.
    •   AltAdvertisment
    Points: 49, Level: 1
    Nov 2017
    7
    49
    Hi Mate. Yes,You can try to change it into 3 PP, 2Fr4, and make copper thickness symmetry, which will be helped to lower your cost in some certain.
    Points: 12,220, Level: 26
    Feb 2010
    UNITED KINGDOM
    1,932
    12,220
    26
    Quote Originally Posted by Kennolde View Post
    The board is symmetrical, its around the board centre line that is critical. As the copper weights are all the same for the inner layers you can have it built how you want foil or cores. You can have what you want these days, but anything other than a manufacturers standard method does involve extra cost...
    •   AltAdvertisment
    Points: 107, Level: 1
    Jul 2017
    107
    Hi Kennolde,
    Your stackup is symmetrical and balanced as copper weights are equal on both sides of core. This makes it a standard 6-layer stackup.
    But this would not be the best if your are using it for EMI/EMC application. I would recommend this:Click image for larger version.
    There are 4 things that make this stackup work well.
    - The close proximity of ground to EVERY trace.
    - Signal 3’s secondary reference plane (Layer 4) is much greater than the distance to Layer 2.
    - The close proximity of Power and Ground Planes creates planner capacitance.
    - Tracing between signal layers 1 and 3 requires no special treatment.
    Let me know if you need anything else on this.
  7. #7
    Newbie level 2
    Dec 2017
    24
    Thanks my friend, I've got the way from a pcbastore, it will be like( SM/Copper/PP/Core/PP/Core/PP/Copper/SM ) which is the cheapest stackup for my design
  8. #8
    Newbie level 2
    Points: 71, Level: 1
    Dec 2017
    Shenzhen, Guangdong, China
    71
    Actually, your PCB manufacture will help to measure the impedance cording to the design you give
