Results 1 to 5 of 5
    Full Member level 5
    Points: 2,501, Level: 11
    Nov 2011
    india
    285
    2,501
    11
    What's the problem in my C program?
    Hello
    I wrote program to find largest of three numbers. I am using gcc compiler. When I was compiling first time it was showing some result but again when I tried to complies same program it showing error. Now I don't why it's happening. what's wrong in program or compiler ?
    Program
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    #include <stdio.h>
    int main(void)
        int a, b, c, max;
        max = a;
        printf(" enter three numbers \n ");
        scanf("%d %d %d",&a,&b,&c);
        if(max < b)
            max = b;
        else if(max < c)
            max = c;
        printf("\n largest %d ",max);
     return 0;
    Error
    hello.c:16:6: error: stray '\240' in program
    A A A A A A A A max = c;
    hello.c:16:7: error: stray '\302' in program
    hello.c:16:8: error: stray '\240' in program
    hello.c:16:9: error: stray '\302' in program
    •   AltAdvertisment
    Points: 6,329, Level: 18
    Apr 2016
    1,342
    6,329
    18
    Re: What's the problem in my C program?
    you have special characters that are probably not visible in your text editor but are caught by your compiler. just google 'stray \240' and the very first hit explains it well.
    Really, I am not Sam.
    •   AltAdvertisment
    Full Member level 5
    Nov 2011
    india
    285
    2,501
    11
    Quote Originally Posted by ThisIsNotSam View Post
    I copy paste code, that I have already made because it take a lot of time to write new code every time. I used to do this But then there was no problem. It's been happening for a few days. how to fix this issue
    •   AltAdvertisment
    Apr 2016
    1,342
    6,329
    18
    whatever you are copying from, it already has the issue in it. very very simple.. I mean, if you can't debug this incredibly naive mistake, how are you going to write software?
    Points: 11,941, Level: 26
    Apr 2010
    1,830
    11,941
    26
    this situation may happen when the source is in utf and target is ascii edior.
