Results 1 to 4 of 4
    Junior Member level 1
    Points: 106, Level: 1
    Nov 2017
    15
    106
    coding help needed in verilog
    what is moving average filter? how do i get samples of a signal in verilog?
    •   AltAdvertisment
    Advanced Member level 3
    Points: 5,356, Level: 17
    Feb 2015
    887
    5,356
    17
    Re: coding help needed in verilog
    moving average typically refers to the FIR filter where the previous N samples are added together and then the result is multiplied by 1/N. This filter is common because a recursive implementation requires very little resources.
    It should not be hard to find examples of this filter throughout the internet.
    Getting samples to the filter is up to you. for simulation, you can use readmem or other file functions. For a working design you would need to interface to an ADC or something that can send the FPGA samples.
    •   AltAdvertisment
    Nov 2017
    15
    106
    •   AltAdvertisment
    Points: 61,937, Level: 60
    Apr 2014
    12,624
    61,937
    60
    What do you mean?
    Are you asking about how to use an ADC?
    A design usually starts with defining the task:
    * input signal definition
    * output signal definition
