Results 1 to 3 of 3
    Newbie level 2
    Points: 19, Level: 1
    Nov 2017
    19
    [moved] VHDL for IEC 18000-63 Type C-protocol (EPC Gen2 protocol)
    Hello
    Hello everyone, I'm new here and new in VHDL aswell. I'm doing a project in EPC Gen2 protocol and for that i need a help to write a code to implement this protocol. If there is anyone who has already work in this topic. I would really appreciate if he/she can help me in this topic.
    Thank you,
    suha4744
    •   Alt7th November 2017, 23:46
      advertising
    Points: 36,062, Level: 46
    Jun 2010
    6,589
    36,062
    46
    Re: [moved] VHDL for IEC 18000-63 Type C-protocol (EPC Gen2 protocol)
    What have you done already and what problems are you having?
    •   Alt8th November 2017, 09:17
      advertising
    Newbie level 2
    Nov 2017
    19
    First of all, Thank you for the response.
    Currently, i'm going through literature study where i encounter with this Select command. From the literature where it mention
    MemBank specifies how a Tag applies Mask. If MemBank=002 then the Tag searches for at least one file
    whose FileType matches Mask. If MemBank=012, 102, 112 then a Tag applies Mask to the EPC memory
    bank, TID memory bank, or File_0, respectively. A Select specifies a single FileType or memory bank.
    Successive Selects may apply to different file types and/or memory banks.
    • Pointer specifies a starting bit address for the Mask comparison. Pointer uses EBV formatting (see Annex
    A) and bit (not word) addressing. If MemBank=002 then an Interrogator shall set Pointer to 00h; if a Tag
    receives a Select with MemBank=002 and a nonzero Pointer value then it shall ignore the Select.
    • Length specifies the length of Mask. Length is 8 bits, allowing Masks from 0 to 255 bits in length. If Mem-
    Bank=002 then an Interrogator shall set Length=000010002; if a Tag receives a Select with MemBank=002
    and Length<>000010002 then it shall ignore the Select.
    If we choose MemBank="01" how we should write code in VHDL for matching case?
    If anyone can help me on this, that would me really helpful.
    Thank you,
    suha4744
