Results 1 to 7 of 7
    Junior Member level 3
    Points: 335, Level: 3
    Mar 2017
    28
    335
    Latches create in verilog code
    i create 1d array in verilog code like this
    Code Verilog - [expand]
    8
    9
    10
    reg[7:0]  channel[1:length-3];
    integer i ;
    initial
     begin
      for (i = 1 ; i <= length-3 ; i = i+1)
       begin
        channel[i] = i * 10;
       end
     end
    now in always blocks i am comparing some input logic like this
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    always@ (posedge clk or posedge rst )
         begin
         if (rst)
          begin
                 cts_1 = 11'bz ;
             cts_2 = 11'bz ;
             cts_3 = 11'bz ;
             cts_4 = 11'bz ;
             cts_5 = 11'bz ;
             cts_6 = 11'bz ;
             cts_7 = 11'bz ;
             cts_8 = 11'bz ;
             count = 1 ;
             count1 = 0 ;
         end
        else
             begin
            if( user[1:3] == 3'b000 &&  count1[0]!=1 )   //Count1---only one time access only
                 begin
                  cts_1= {3'b000,channel[count]};
                  count=count+1;
                  count1[0]=1;
                 end
                else
              begin
                  cts_1 = cts_1;
                 end
    the line "cts_1= {3'b000,channel[1]};" give latches
    now question is how to remove latches. and why this line create latches
    Last edited by andre_teprom; 3rd November 2017 at 07:51. Reason: added SYNTAX tags
    •   AltAdvertisment
    Points: 36,169, Level: 46
    Jun 2010
    6,614
    36,169
    46
    Re: latches create in verilog code
    Because you are using blocking assignments.
    Use non-blocking ( <= ) assignment instead.
    Also, why are you resetting all the values to z?
    •   AltAdvertisment
    Points: 245,688, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,684
    245,688
    100
    Blocking assignments in edge sensitive always block is surely bad design practice (don't consider special cases where they are intentionally used). But I don't understand how they could cause latch generation in this case.
    I rather guess the posted code is somehow "like" the original code but essentially different. It would be a good idea to report the respective synthesis warning exactly, and to post complete entity code including variable definitions, so that we can compile it for test.
    •   AltAdvertisment
    Advanced Member level 3
    Points: 5,356, Level: 17
    Feb 2015
    887
    5,356
    17
    the initial block may have some issues -- I know some tools will accept this as a warning. Using integer types in an initial block can result in the synthesis ignoring this. If that is an issue, use generate and genvar.
    I also don't see any latches here. My suspicion is that a different file is being used in synthesis or there is some other issue with the original post.
    last, "cts_1 = cts_1;" is not needed.
    Mar 2017
    28
    335
    i know that else statement is not necessary but it actually sure that not to create latches. because missing if else statement cause latches... i also initialize cts with zero but same warning show.
    the complete code is
    module channel_selector(user,rst,clk,cts_1,cts_2,cts_3,cts_4,cts_5,cts_6,cts_7,cts_8);
    parameter length = 11;
    output reg [1:length]cts_1,cts_2,cts_3,cts_4,cts_5,cts_6,cts_7,cts_8;
    input [1:(length-3)*3]user;
    input clk,rst;
    reg [7:0] count1 =0;
    reg [7:0]  channel[length-4:0];
    reg [1:length-3] count = 0;
    integer i ;
    initial
     begin
      for (i = 0 ; i <= length-4; i = i+1)
       begin
       end
     end
    	 begin
    	 if (rst)
    	  begin
    	    cts_1 =  0 ;
    		 cts_2 = 11'bz ;
    		 cts_3 = 11'bz ;
    		 cts_4 = 11'bz ;
    		 cts_5 = 11'bz ;
    		 cts_6 = 11'bz ;
    		 cts_7 = 11'bz ;
    		 cts_8 = 11'bz ;
    	  	 count = 0 ;
    		 count1 = 0 ;
         end
       	else
    		 begin
          	if( (user[1:3] == 3'b000) && (count1[0]!=1) )   //Count1---only one time access only
    			 begin
    			  cts_1 = {3'b000,channel[count]};
    			  count=count+1;
    		 	  count1[0]=1;
    			 end
    			else
              begin
    			  cts_1 = cts_1;
    			 end
    			 if( (user[4:6] == 3'b001)  &&  (count1[1]!=1) )
    			 begin
    			  cts_2 = {3'b001,channel[count]};
    			  count=count+1;
    			  count1[1]=1;
    			 end
    			 else
              begin
    			  cts_2 = cts_2;
    			 end
    			 if( user[7:9] == 3'b010    &&  count1[2]!=1  )
    			 begin
    			  cts_3 = {3'b010,channel[count]};
    			  count=count+1;
    			  count1[2]=1;
    			 end
    			 else
               begin
    			   cts_3 = cts_3;
    			  end
    			 if( user[10:12] == 3'b011    &&  count1[3]!=1 )
    			  begin
    			  cts_4 = {3'b011,channel[count]};
    			  count=count+1;
    			  count1[3]=1;
    			  end
    			 else
               begin
    			   cts_4 = cts_4;
    			  end
    			 if( user[13:15] == 3'b100   &&  count1[4]!=1  )
    			  begin
    			  cts_5 = {3'b100,channel[count]};
    			  count=count+1;
    			  count1[4]=1;
    			  end
    			 else
               begin
    			   cts_5 = cts_5;
    			 end
    			 if( user[16:18] == 3'b101    &&  count1[5]!=1  )
    			 begin
    			  cts_6 = {3'b101,channel[count]};
    			  count=count+1;
    			  count1[5]=1;
    			 end
    			 else
               begin
    			   cts_6 = cts_6;
    			  end
    			 if( user[19:21] == 3'b110    &&  count1[6]!=1 )
    			 begin
    			  cts_7 = {3'b110,channel[count]};
    			  count=count+1;
    			  count1[6]=1;
    			 end
    			 else
               begin
    			   cts_7 = cts_7;
    			 end
    			 if( user[22:24] == 3'b111 &&  count1[7]!=1  )
    			 begin
    			  cts_8 = {3'b111,channel[count]};
    			  count=count+1;
    			  count1[7]=1;
    			 end
    			 else
               begin
    			   cts_8 = cts_8;
    			  end
     		end
     	 end
    endmodule
    i know else statement is not necessary but it actually sure that not to create latches because missing if else statement might cause latches. I also initialize cts_1... with zero but same warning again show
    the warning show is
    WARNING:Xst:1781 - Signal <channel> is used but never assigned. Tied to default value.
    WARNING:Xst:1710 - FF/Latch <Mtridata_cts_8_10> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_8_9> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_8_8> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_7_10> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_7_9> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_7_8> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_6_10> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_6_9> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_6_8> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_5_10> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_5_9> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_5_8> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_3_10> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_3_9> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_3_8> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_4_10> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_4_9> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_4_8> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_4<8> and Mtridata_cts_4<9> Mtridata_cts_4<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_4<10> and Mtridata_cts_3<8> Mtridata_cts_3<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_4<8> and Mtridata_cts_3<9> Mtridata_cts_3<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_3<10> Mtridata_cts_3<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<10> and Mtridata_cts_5<8> Mtridata_cts_5<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<10> and Mtridata_cts_5<9> Mtridata_cts_5<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_5<10> Mtridata_cts_5<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_6<8> Mtridata_cts_6<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<10> and Mtridata_cts_6<9> Mtridata_cts_6<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_6<10> Mtridata_cts_6<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<10> and Mtridata_cts_7<8> Mtridata_cts_7<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_7<9> Mtridata_cts_7<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_7<10> Mtridata_cts_7<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_8<8> Mtridata_cts_8<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_8<9> Mtridata_cts_8<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_8<10> Mtridata_cts_8<10> signal will be lost.
    WARNING:Xst:2404 - FFs/Latches <Mtridata_cts_3<10:10>> (without init value) have a constant value of 0 in block <channel_selector>.
    WARNING:Xst:2404 - FFs/Latches <Mtridata_cts_4<10:10>> (without init value) have a constant value of 0 in block <channel_selector>.
    WARNING:Xst:1710 - FF/Latch <Mtridata_cts_6_8> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_8_10> (without init value) has a constant value of 1 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_6<8> and Mtridata_cts_6<10> Mtridata_cts_6<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_6<9> and Mtridata_cts_5<8> Mtridata_cts_5<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<8> and Mtridata_cts_5<9> Mtridata_cts_5<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_6<10> and Mtridata_cts_5<10> Mtridata_cts_5<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<8> and Mtridata_cts_7<8> Mtridata_cts_7<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<10> and Mtridata_cts_7<9> Mtridata_cts_7<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<10> and Mtridata_cts_7<10> Mtridata_cts_7<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<10> and Mtridata_cts_8<8> Mtridata_cts_8<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<10> and Mtridata_cts_8<9> Mtridata_cts_8<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<10> and Mtridata_cts_8<10> Mtridata_cts_8<10> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<8> and Mtridata_cts_3<8> Mtridata_cts_3<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_5<10> and Mtridata_cts_3<9> Mtridata_cts_3<9> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_4<8> Mtridata_cts_4<8> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<9> and Mtridata_cts_4<9> Mtridata_cts_4<9> signal will be lost.
    WARNING:Xst:1710 - FF/Latch <Mtridata_cts_6_0> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_6_7> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_5_0> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_5_7> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_7_0> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_7_7> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_8_0> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_8_7> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_3_0> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_3_7> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_4_0> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <Mtridata_cts_4_7> (without init value) has a constant value of 0 in block <channel_selector>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_6<0> Mtridata_cts_6<0> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_6<7> Mtridata_cts_6<7> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_5<0> Mtridata_cts_5<0> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_5<7> Mtridata_cts_5<7> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_7<0> Mtridata_cts_7<0> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_7<7> Mtridata_cts_7<7> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_8<0> Mtridata_cts_8<0> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_8<7> Mtridata_cts_8<7> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<8> and Mtridata_cts_3<0> Mtridata_cts_3<0> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<0> and Mtridata_cts_3<7> Mtridata_cts_3<7> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<0> and Mtridata_cts_4<0> Mtridata_cts_4<0> signal will be lost.
    WARNING:Xst:638 - in unit channel_selector Conflict on KEEP property on signal Mtridata_cts_3<0> and Mtridata_cts_4<7> Mtridata_cts_4<7> signal will be lost.
    WARNING:Xst:2677 - Node <count_5> of sequential type is unconnected in block <channel_selector>.
    WARNING:Xst:2677 - Node <count_4> of sequential type is unconnected in block <channel_selector>.
    WARNING:Xst:2677 - Node <count_3> of sequential type is unconnected in block <channel_selector>.
    WARNING:Xst:2677 - Node <count_2> of sequential type is unconnected in block <channel_selector>.
    WARNING:Xst:2677 - Node <count_1> of sequential type is unconnected in block <channel_selector>.
    WARNING:Xst:2042 - Unit channel_selector: 11 internal tristates are replaced by logic (pull-up yes): N10, N11, N12, N13, N14, N15, N16, N17, N18, N19, N20.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,684
    245,688
    100
    Re: Latches create in verilog code
    As previously guessed, the "complete code" doesn't create latches.
    You are essentially misunderstanding compilation warnings like this
    It's a warning about removing signals that have no effect on the design output during optimization. "FF/Latch" refers to any memory element, not specifically latches.
    I didn't check if the design serves a useful purpose, but there are no latches.
    It does in combinational always block, not in registered code.
    •   AltAdvertisment
  7. #7
    Mar 2017
    28
    335
    Yes FVM you are right. I alright solve that problem.
