Results 1 to 3 of 3
    Member level 5
    Points: 1,025, Level: 7
    May 2015
    85
    1,025
    7
    Altering some bits of a RAM location
    Is it possible to alter specific bits of a RAM location?
    For example: A RAM location has some contents(say 00011000), I need to add 4(100) to the contents i.e the contents will be changed to (00011100). Can I just directly invert 2nd bit of the RAM? The only way I know is to generate address of that location in one cycle, in next cycle we will get the contents and alter then and write them back. This consumes two clock cycles. If we can directly send '1' to the second bit location without altering the other bits, it may save a clock cycle(if possible)
    •   Alt6th October 2017, 06:53
      advertising
    Points: 20,802, Level: 35
    barry's Avatar
    Mar 2005
    California, USA
    4,008
    20,802
    35
    Re: Altering some bits of a RAM location
    if you're using block RAM I don't think you can do this. But you could create a RAM with bit-enables; it might take up a lot of resources.
    •   Alt6th October 2017, 07:34
      advertising
    Points: 36,062, Level: 46
    Jun 2010
    6,589
    36,062
    46
    The rams usually have byte enable signals, so you can modify individual bytes, but not bit enables.
    At that level, the only way to alter is to read-modify-write.
