Results 1 to 3 of 3
    Full Member level 5
    Points: 1,831, Level: 9
    Disha Karnataki's Avatar
    Jul 2013
    india
    250
    1,831
    9
    motor selection for glass cleaning
    I am making a solar panel cleaning robot and want to select appropriate motor for the selected roller brushes for the cleaning.
    The brushes are as shown: https://3.imimg.com/data3/MN/MJ/MY-8...es-250x250.jpg
    The dimensions of brushes are: InnerDia:0.7",Outer dia(along with bristle):4.3",bristel(made of teflon) thickness:2mm, length of brush:12"
    I read some papers which conducted analysis in saudi arabia for soiling effect and there was 35% effeciency reduction in o/p for 300um dust accumulation on the panels and after applying force of 0.15N to 0.3N tangentially(they rubbed/scratched the surface) along the surface they could remove the dust and could increase the effeciency so, now I want to accomplosh this cleaning using roller brushes how do I go about selecting the motors?
    •   AltAdvertisment
    Points: 61,971, Level: 60
    Apr 2014
    12,631
    61,971
    60
    Re: motor selection for glass cleaning
    The type of motor depends on your power source. AC, 1 phase, three phase, DC, Battery...dynamics in RPM and torque
    Do you have/need a gearbox or not?
    The power of the motor is: P = M x 2 x Pi x n
    Where M is the torque in Nm
    And n is the rotation speed in 1/s
    You need to add some headroom.
    •   AltAdvertisment
    Points: 14,176, Level: 28
    Nov 2012
    2,627
    14,176
    28
    Quote Originally Posted by Disha Karnataki View Post
    ...The dimensions of brushes are: InnerDia:0.7",Outer dia(along with bristle):4.3",bristel(made of teflon) thickness:2mm, length of brush:12"...
    You need to tell us the rotational speed and the pressure on the brush. Remember that the brush will help loosen the dust from the surface AND you have to ensure that the dust is washed off (wet cleaning) or sucked off (dry vacuum cleaning)
    The 300um dust accumulation refers to particle size of the dust OR the thickness of the dust layer on the surface?
    One important point is that the brushes should not generate static.
