Results 1 to 5 of 5
    Member level 3
    Points: 417, Level: 4
    Jul 2017
    59
    417
    MAX II cpld volatile programming
    can i do the volatile programming in max ii cpld?
    •   Alt3rd October 2017, 13:08
      advertising
    Points: 29,073, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,687
    29,073
    41
    Re: MAX II cpld volatile programming
    Quote Originally Posted by hareeshP View Post
    Huh!!?? Do you think that the non-volatile MAX II CPLD has a SRAM based "volatile" programming mode?
    If you think a flash based (i.e. non-volatile) part has a volatile programming mode, maybe you need to do more research, like reading the MAX II documentation.
    •   Alt3rd October 2017, 15:38
      advertising
    Points: 244,831, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,523
    244,831
    100
    There's no volatile programming option for MAX II and MAX V. Newer MAX 10 however has it.
    •   Alt3rd October 2017, 16:26
      advertising
    Member level 3
    Jul 2017
    59
    417
    thanks for your reply. I have one more doubt, i have read about cfm( configuration flash memory) it is used for isp( in system programming). Does it mean cfm can only be programmed while the board is currently running?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,523
    244,831
    100
    Everything described in the MAX II Device Handbook which you should read. See Chapter 11. In-System Programmability Guidelines for MAX II Devices.
    VCCIO of all I/O banks and VCCINT of the device must be fully powered up for ISP to function.
