+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 4
    Points: 1,741, Level: 9
    Join Date
    Jul 2014
    Posts
    216
    Points
    1,741
    Level
    9
    Cyclone 5 sockit usb_uart port
    hi,
    i have cyclone 5 sockit. inthe fpga , there is usb uart port. but its a part of the HPS, not fpga. so is it possible to use tha usb uart port using nios processor ?
    i mean nios2 processor +uart (rs232)+on chip ram ??
    Click image for larger version.
    thanks and regards
    •   AltAdvertisment
  2. #2
    Super Moderator
    Points: 245,674, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    42,684
    Points
    245,674
    Level
    100
    Re: cyclone 5 sockit usb_uart port
    No, there's no direct connection between FPGA fabric and dedicated HPS IO pins.
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Full Member level 2
    Points: 829, Level: 6
    Join Date
    Apr 2017
    Posts
    122
    Points
    829
    Level
    The easiest way is to use UART-2-USB cable like this one
    http://uk.rs-online.com/web/p/kvm-mi...blies/6877834/
    and hook-up wires to I/O pins from FPGA part of the chip. Remember to use cables/adapters with 3.3V IO levels only - the FPGA pin won't survive 5V at the input.
    •   AltAdvertisment
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    42,684
    Points
    245,674
    Level
    100
    You rather want the USB-2-TTL-UART than USB-2-RS485 cable. E.g. FTDI TTL-232R-3V3
    http://uk.rs-online.com/web/p/interf...-kits/0429307/
  5. #5
    Full Member level 2
    Join Date
    Apr 2017
    Posts
    122
    Points
    829
    Level
    Quote Originally Posted by FvM View Post
    Yes, I overlooked specs - it must be TTL UART 3.3V not RS485.
    One can use cheaper adapter like this one:
    http://www.ebay.co.uk/itm/CH340-CH34...8AAOSwx6pYqKJD
    or this one
    http://www.ebay.co.uk/itm/USB-2-0-to...sAAOSwa81Zc7ok
    There is a plenty of various sorts/types/kinds at eBay and similar websites.
  6. #6
    Full Member level 4
    Join Date
    Jul 2014
    Posts
    216
    Points
    1,741
    Level
    9
    hi,
    thanks for the replay fvm & filip.amator. actually i need to take two register value from fpga (both 32 bit)to pc for evaluation. now i done it with jtag uart+nios 2 processor. but the speed is around 5k . but i need a speed of 10 k. so i thought i will use uart (rs 232 ip). but its not working . so anybody know how to do it with hps . do i need to implement a qsys system for that(like jtag uart) . if yes what components i nee to add (like hps+onchip ram+uart +??). i didnt got any reference design if anybody had it please send a link .
    i am using "sockit" from terasic .
    regards
  7. #7
    Full Member level 2
    Join Date
    Apr 2017
    Posts
    122
    Points
    829
    Level
    Re: Cyclone 5 sockit usb_uart port
    You can use PIO component (8 bits for data and one bit to start UART) in NIOS2 processor to send characters over UART to the host PC. Take UART_TX.vhd from this website: https://www.nandland.com/vhdl/module...ort-rs232.html and wire signals between NIOS2 and UART core: i_TX_Byte to 8 bit PIO with your data and i_TX_DV to start UART.
    •   AltAdvertisment
  8. #8
    Full Member level 4
    Join Date
    Jul 2014
    Posts
    216
    Points
    1,741
    Level
    9
    sending 64 bits from fpga to pc using hps @10khz
    hi,
    i had a terasic sockit (which had a cyclone 5 soc). i already implemented sending 64 bit data from fpga to pc by using nios2 processor
    ( nios2+jtag uart_onchipram). but its speed is very low(around 2to 3khz) , i am not able to get 10khz speed. so what should i do??
    sockit had a usb to uart port which is integrated to hps, i think by using it, i can increase the speed. but how can i use it?
    along with hps what are the components i need to use in QSYS system?
    if anybody got a reference program lease share the link , it will be very helpful to me
    is it possible to use qsys system to run the hps like i did using nios2 processor ?( is it possible to use hps without booting form an sd card)
    if it not possible how can i do it , any tutorial for that ?
    for sending data is it necessary to boot it from a sd card, is there any other way ?, like i did using nios processor
    my future work is to change one register value inside fpga from a terminal form pc (using hps) .
    if anybody know any information regrading this, please share ( i am using quartus 16.0 lite edition in windows7)
    thanks and regards
    Last edited by FvM; 25th October 2017 at 15:33. Reason: Merged with previous SoC + UART thread
