bhl777
Full Member level 6
Hi All, I was looking at some datasheet of the interleaved buck converters.
Usually people design interleaved buck converter, and I am curious what is the problem if we do not have good interleave?
One drawback I can see is the output voltage ripple cancellation effect. Having a good phase shift can maximumly reduce the output voltage ripple. In addition to that, is there any other reasons we should use the interleave?
Thank you!
Thank you!
