Results 1 to 4 of 4
    Points: 118, Level: 1
    Sep 2017
    118
    dual band dipole antenna (13.5 MHz and 866 MHz) in CST
    hello everyone
    quite new in this field so please have some patience with me
    i have to design a dual band dipole antenna resonating at 13.5 MHz and 866 MHz with port impedance 13-13.5 (real) and 120-130(imaginary) parts with dimensions not greater than 40 by 40 mm2
    i have designed some antennas in CST so familiar with the software.My big dilemma is how do i start this?Am i just choosing a random shape and work on it?or there is other way of planning it before implementing in CST?
    your help is much appreciated
    •   Alt13th September 2017, 12:11
      advertising
    Points: 244,657, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,499
    244,657
    100
    Re: dual band dipole antenna (13.5 MHz and 866 MHz) in CST
    As for the 13.5 MHz antenna, it's simply impossible. A antenna with the given size, either loop or dipole, will have a radiation resistance in the low milliohm range.
    Are you actually designing a 13.5 MHz antenna? Or an inductive near-field coupler?
    •   Alt13th September 2017, 12:50
      advertising
    Sep 2017
    118
    it is a RFID tag
    •   Alt13th September 2017, 12:58
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,499
    244,657
    100
    For 13.56 MHz, an inductive coupler (e.g. a printed coil with 5 or 10 windings) is the only reasonable way to implement the tag "antenna". For 886 MHz, a shortened dipole is feasible.
